I want a Canon Powershot SD300 camera
   / I want a Canon Powershot SD300 camera #1
etpm
Whidbey Island, WA
Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Hi All,
Years ago I modified a Canon Powershot SD300 to take pictures in the near infrared and near UV. To do this I had to take the camera apart to remove an internal filter and replace the filter with a piece of quartz glass made from a microscope slide the same thickness as the filter I removed. I now use filters in front of the camera to only let in IR or UV or both. Somehow the LCD screen on the camera suffered damage so I need a new one. This is just a silly hobby of mine that I don't spend much money on, so if anyone here has one of these old cameras not being used and would like to part with it for little to no money I would love to take it off of your hands. I have tried ebay several times but nobody will or can test the LCD screen on the parts camera they are selling and I don't want to buy a bunch of cameras just to find out that the one part I need doesn't work. As I said, this is a cheap hobby. But I do get some interesting pictures now and then.
Thanks,
Eric
   / I want a Canon Powershot SD300 camera #2
Greetings Xfaxman,
Thanks for the reply and the link. I will try to see if someone there can help me. I can buy a working camera but all I can find at the moment are more money than I can justify for a silly hobby. I especially like your suggestion that the LCD from other camerea models might work. I am getting some really cool pictures though. Looking through the UV filter makes for some interesting stuff. BTW, for the UV filter I bought a blacklight light bulb. The glass was, I assume, Wood's glass. Anyway, I turned on the lathe a plastic filter holder that fits over the camera lens and holds either the UV or IR filter. Then I made a saw from bronze that I charged with diamond paste. I used the saw to cut discs from the bulb. The discs are of course rounded but it doesn't seem to make much difference to the pictures. I made IR filters from old floppy discs using a gasket punch.
Eric
Pictures, we need pictures.
I found a Powershot SD400 for 20 bucks and it appears to be the same camera except it has a higher pixel count and some othet features not found in the SD300. It arrives soon so I am going to modify it the same way. When done I will post pictures from it.
Eric
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
More info coming soon! (A55851)
More info coming...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2008 Ford F-450 14FT Flatbed Truck (A51692)
2008 Ford F-450...
