orlo
Platinum Member
What exactly is a York rake? I've pulled a 5' landscape rake and a 6' grader blade with the 2305 without any issue But the 2320 and 2520 are more capable tractors especially when it comes to implements and 3pt work. Also the 2305 only has a 'select control' instead of position control on the 3pt.
I agree about cleaning, but the 62D on the 2305 comes off in a flash and can be flipped on it's side to clean (As long as you lean it up against something). Taking on and off the 72"MMM on the 3000 series is a pain by comparison (I just did it yesterday..
One other note. the 2305 and 2320 have nice convenient dial height adjuster knobs. The 2520 has no such knob and I've been told that it's just like the adjustment on my 3000 series which amounts to a non-marked large hand nut. No calibrations, etc. on the 2305 and 2320 you can change height (and go back to a place you know) without even leaving the seat. A big plus if mowing is your primary chore.
A 5' brush hog for the 2305 I think would be way to big. Although deer shows it as ok on the 2320 and 2520 I would think it's even a little big for the 2320 and 2520. Not a power thing, just that it seems physically huge for the smaller tractors. I do know folks here run that setup though. I run an LX5 5 footer on my 3720 (formerly on my 3320).
All the 2000 series will take the 47" snowblower but I've heard folks with the 2520 (maybe the 2320 also) complain about 'runover' with the wheels. The wheels on the 2320 and 2520 are wider than the 47" clearing path of the blower. On the 2305 it just about matches so it works well. I don't know if deere offers 'wings' to bring out the front sides of the blower an inch or two but some folks here have talked about them.
One other thing. I don't know if this applies to the 2520, but the 2320 has the same engine as the 2305 and is geared higher so folks have stated that unless your mowing perfectly flat land mowing in the high range is difficult so they stay in the low range which is slower than the high range on the 2305. On the 2305 mowing in high range is possible even for moderate (not steep) slopes so in effect you can probably mow faster under some conditions with the 2305 than with the 2320. The 2520 has more HP but is geared high also so I'm not sure if folks have the same issue with it).
