aesanders
Platinum Member
- Joined
- Aug 12, 2005
- Messages
- 981
- Location
- Alachua County, Florida
- Tractor
- LS MT3 42 S HST cab, BCS 830 2 wheel tractor, Gravely Pro-Turn 160 XDZ, John Deere Gator HPX 615e
Z-Michigan said:I've hesitated to stay in this particular discussion because I have only a few months experience, but in that limited time my reasons to hesitate on using the brushhog for just grass are:
1) Cut quality - I am finding erratic cut quality on grass with my LX6, which is nearly new (20 hours or less of use since brand new) and not beat up. Sometimes it does a very good job, sometimes it seems to miss a lot. Often the job looks good immediately afterward but in a day or two I find a lot of the grass/weeds was just bent over and not actually cut off. Now on woody stuff the LX6 is great, slicing right through. It also seems to work better on lush, tall grass than it does on thin mixed weeds and grass, but the latter needs mowing more than lush grass does.
2) Ground damage - I believe I have everything adjusted optimally (tailwheel height with front lower than rear of cutter, links in float position, etc.) but I still find I am often damaging the underlying ground with the brush mower, either from the tailwheel or side skids. Maybe further adjustment would stop this, maybe not. It seems to be a worse problem when grass is thin and scraggly with some weeds, but that is the type of area that, if in pasture, needs cutting and may need repeated cutting. Ground damage to a pasture just sets back your pasture renovation/maintenance, which is presumably why you were mowing the pasture in the first place.
I definitely wouldn't sell my LX6 nor would I use a finish mower on trees and woody, thick weeds, but on thin weeds mixed with grass I find that our riding mower (cheapo MTD) seems to do a better job than the LX6 on my tractor.
I've used a bunch of different Brush cutters and they all work similar to how you described yours. Their cut quality just isn't that great. The work great on heavier brush that you are just trying to get rid of or extremely overgrown pastures, but for the average pasture that isn't too rough I prefer the finish mower.
