I think another way to look at this is by stating what features you DON'T want or need. Money saved in these areas can be better spent on other, more useful features.I figured we could start a thread for the Kubota execs to readif you were at the table when the new BX or "Max killer" tractor was designed, what would you insist Kuboypta includes to leap frog the competition without breaking the bank?
What features would YOU like Kubota to put in the next generation of SCUT it CUT tractors?
Examples:
1) Turn signals on the BX, to me, are a complete waste. So, ditch the turn signals and mount a proper rear worklight, or two. Net cost is zero, in fact this might be an overall cost reduction.
2) Rear diff lock -- again, to me there is questionable value to this on a 4WD-capable tractor which neither weighs all that much nor has lots of ground clearance. Where you can get the BX stuck is rather limited by the ground clearance, and when you do get stuck it's not clear the diff lock is going to have much positive benefit. You can say, "but it will be there when I need it", however wouldn't you rather have a better seat or some such with the "savings" -- something you are using ALL of the time?
n.b.
There are some comments I would tend to disagree with in a couple of posts above. For example, the HST fan protection. I don't think this is a cost adder -- the fact is that Kubota probably has to fix a lot of broken fans under warranty, and that costs the company money and goodwill. It's probably cheaper, looking at the "full stream cost" to Kubota, to simply mount a sturdy guard under the HST fan. Sometimes more is less, especially if it knocks down a VERY expensive warranty fix.
Wrooster
