If I bolt 2" PVC to edge of snowblower, will it eat it?
   / If I bolt 2" PVC to edge of snowblower, will it eat it? #11
I think the impeller would just blow right through that PVC, I have hit some pretty big branches with mine and it just blew right through them!
   / If I bolt 2" PVC to edge of snowblower, will it eat it? #12
My dogs manage to poop just fine, no matter how deep the snow,
How do you clean it up? Or do you just wait until spring?
   / If I bolt 2" PVC to edge of snowblower, will it eat it? #13
Yes, but the skid shoes would just dig into the lawn.
I'm going to try it in the next snowstorm, which shouldn't be too long.
I'm not seeing how the skids are digging as mine dont with the blade set at 1.5" off the ground (use a 2x4).. But, could you not make 'skis' by bolting the PVC along side/over the skid shoes? Front to back on each side, not across.
edit: I did replace the metal skids with these much larger poly ones:
http://www.amazon.com/Arnold-490-241-0010-Universal-Deluxe-Throwers/dp/B002MRM6KQ
   / If I bolt 2" PVC to edge of snowblower, will it eat it? #14
Pvc pipe gets extremely brittle when it gets cold. It will probably not hold up.
   / If I bolt 2" PVC to edge of snowblower, will it eat it? #15
How about the black poly pipe? That is not so brittle.
If the PVC works OK on the first trial, I will change to ABS or iron pipe. I had the PVC in stock and have already slit it and bolted it to the cutting edge. We're expecting some snow tonight.
Amazon.com: Arnold 490-241-0010 Universal Deluxe Poly Slide Shoes For Most 2 Stage Snow Throwers: Patio, Lawn & Garden
My stock skids are much smaller than those. The ski idea may work, but would be more work to attach and remove, and I want to be able to quickly take it off for my blacktop driveway. I think this is going to work. If the weatherman is correct, I should have the answer tomorrow....along with another genius idea, to be announced tomorrow...if it works.:)
   / If I bolt 2" PVC to edge of snowblower, will it eat it? #18
If the auger turns freely without hitting it, then why not try it? Most it cost you is a couple sheer bolts. :) If it doesn't hold up, try PVC Schedule 80, it's a lot more heavy duty than the standard Schedule 40.
   / If I bolt 2" PVC to edge of snowblower, will it eat it? #19
Pvc and abs do not do well with cold. If you hit a cold piece of pvc on something it will crack if you hit it hard it will shatter like a bomb was in it. Poly may do better, steel should work fine, now if you could make a steel roller?
   / If I bolt 2" PVC to edge of snowblower, will it eat it? #20
Ya, my stock skids were much smaller too, and worn.. So I changed to these. They actually fit all the way front to back and dont dig into my sandy driveway. In fact, I have to do a little 'up' pressure on the handles to keep the nose planted :)
if you get a chance, try them out. At $30, they are worth it IMHO.
White Metal Roof Panels (A55758)
White Metal Roof...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
Toro Zero Turn (A50324)
Toro Zero Turn...
2016 FORD F-550XL SUPER DUTY SERVICE TRUCK (A52706)
2016 FORD F-550XL...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
