Ignition Switch Problem
/ Ignition Switch Problem #1
parkie456
Moody TX
Branson 3510
Branson 3510 Tractor. Won't start by turning the ignition switch. Does not turn over I get nothing. If I short the selenoid out it will start. Where may I purchase a new switch for it. 2004 Branson 3510 1st problem I have had in 10 years. Thanks for helping.
/ Ignition Switch Problem #2
You may have a wiring problem and not a switch problem.
Thanks for the info. I am going to work on that problem tomorrow. I thought maybe it could be a fuseible link also.
/ Ignition Switch Problem #4
Could be, could also be a safety switch thats engaged somewhere,not letting it start.
/ Ignition Switch Problem #6
Could be- seat switch, clutch switch, out of gear/neutral switch.
Find and check these before buying a new ignition switch.
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
NEW Landhonor Diesel Fuel Transfer Pump (A62679)
NEW Landhonor...
(6) 250 Gallon Chemical Totes (A64127)
(6) 250 Gallon...
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2022 EZ-GO ELITE...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
