IH 254 front axle gear oil change
   / IH 254 front axle gear oil change #11
From the looks of the page from your manual, it seems that the oil has to travel through the hub gear assembly before it can come out at the level holes. If you are using gear oil, such as 80w90, this can take some time for it to make it through the smaller passage ways. Therefore I would personally let the tractor sit overnight so that the oil can make its way to the level holes and drain out till it stops to achieve the correct level.
Hope this helps!!
That's what I was thinking as well. But loggin said it better.
34015 (A53421)
34015 (A53421)
2017 Chevrolet Traverse LS SUV (A55853)
2017 Chevrolet...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55314)
2025 Mahindra 6075...
