I'll sure miss this oak tree...
   / I'll sure miss this oak tree... #11
$1,500 to just drop it, $2,500 total cut & haul everything off, grind stump and grade it level. I started to rent a bucket truck but they had another truck with trailer & tractor. I'd still have to hire helpers. I thought price was OK. Plus they got two more jobs from neighbors seeing them work.
In my area, that's about the going rate for a tree.
Save a chunk and make a wall clock out of part of it. Since it has good memories.
   / I'll sure miss this oak tree... #12
Just a suggestion. If you have some fill dirt have them remove the wood chips from the grinding and fill the hole with dirt. It takes a bit but at some point you will have a huge hole where the stump was and after the wood chips rot.
   / I'll sure miss this oak tree... #13
With little thinking end table tops and stools.
   / I'll sure miss this oak tree... #14
Save some of the solid wood and make something or have an artisan make something...
This is an awesome idea.
I know it's off topic, but that old Nissan Hard Body is pretty cool; they're all long rotted out around here.
The guys are still working. The oak is down, five foot across at base. I saved some pieces of it. We found more trees to cut , really a good price since equipment is here. A bucket truck is great!
   / I'll sure miss this oak tree... #16
I've got approximately 50 large oak trees in my two timbers. Some of them I specifically remember 60 years ago as a kid. I keep encroaching scrub brush trees cut from around them. They deserve their place in the timber. No amount of money could buy them.
In your case, you definitely had to protect your house. It's very easy when planting trees to get them too close to buildings.
   / I'll sure miss this oak tree... #17
Not bad.
I had a large pine (2.5' DBH and maybe 50' to 60' tall looming over my house in Mississippi. I COULD have cut it down myself but any slip in it's fall would have been a royal pain to cleanup.
So 2 years ago I got a guy with a bucket truck and helper. His going rate was $500/decent sized tree to get them to the ground, $3K minimum. He cut the pines in 10' sections and I still need to get them on my sawmill.
I also had several other trees leaning over buildings that needed removal.
/edit - I appreciate postings prices for this type of work, it helps planning.
   / I'll sure miss this oak tree... #18
Just had a resident in my township call me saying a huge Cottonwood tree had blown down across the gravel road he lives on. Asked if the Township would pay him to clean it up? It's on his land. I said no, that's your tree and your responsibility. I'll bring the grader out and get it off the roadway if you can't? He said oh no, I've got a large FWA tractor and a CTL. Just wondered if the Township would pay me to clean it up? People these days.....
   / I'll sure miss this oak tree... #19
FWIW...It's not difficult to mill down a hunk of wood into usable pieces for things other than turning...i.e., jewelry boxes, small display cases for collectables etc...frames, carvings...
Milling can be done with even 10" portable table saws and some chisels...it's nice to have a planer but a cheap belt sander from HF will work....best to dry the wood before spending a lot of time making something worthwhile...
*On a related note*...I work mostly as an advisor with a friend's company...we can build anything from upscale homes to curios...mostly build custom cabinets in the winter...
...We have a large shop with several commercial milling machines and re-saws etc...We also have a 36" cap. BSM and recently built a kiln for lumber up to 14'...
* here is where the relation comes in...new home clients always fret over having to take down trees (on their slice of heaven)...depending on the size and type of trees that have to come down...we can offer anything from exterior siding to interior paneling and everything in between that is usually made of wood made from their own trees...cabinets, doors, trim and moldings, furniture, fixtures...we also have a few lathes and make quite a few table lamps....
Wow! I wish you were close to me. I had them save some random pieces. It's really nice looking wood. Most all the rest went to a landfill. I inherited a lathe and planer but my woodworking knowledge is about nil.
2018 PINSA 130BBL VACUUM TRAILER (A58214)
2018 PINSA 130BBL...
SUV (A59231)
SUV (A59231)
403 (A52706)
403 (A52706)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
