I'm a Believer... No Not the Song... R4 Tire Grooving
   / I'm a Believer... No Not the Song... R4 Tire Grooving #1
LittleBill21
Elite Member
PA
Mahindra Max 26XL, White
First go around since I grooved the tires, big big difference, I don't know if the snow was different, it was definitely heavier, but significantly less trouble this time, almost 0 spinning and hills i needed diff lock and had to spin my way up, i went in reverse (no diff lock at all). To those of you debating, i would definitely do tire grooving before going chains to see if its enough. I am not buying chains now. (90 vs 800)
   / I'm a Believer... No Not the Song... R4 Tire Grooving #2
How long did it take you, and what groover / iron did you use? Looks like you did a great job. Contemplating doing my B2601.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #4
I never thoght about the ATV, good idea.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #5
Tire siping - same idea. I always had my big M/S tires siped on my Jeep. Jeep was light and siping REALLY helped in snow and ice. Local tire store - Les Schwab - has a special tool for siping.
the tool i listed above will do siping, you just need to turn the blade around. siping doesn't work apparently on tractor tires as they don't spin fast enough i guess to have any benefit, thus why tractors get grooved
   / I'm a Believer... No Not the Song... R4 Tire Grooving #7
I did the grooves last yr and it definitely makes a big difference and if your tires are rimgard loaded you will notice the difference.
I have washer fluid in all 4, and a BH hanging off the back. I was smashing frozen snow banks down like it was nothing in High.
   / I'm a Believer... No Not the Song... R4 Tire Grooving #9
I've seen that mentioned here before, how does it work? Not quite sure I understand how these shallow grooves work where the large lugged tires don't.
Simply gives the tire more biting surface into the snow, snow on snow causes friction, friction allows grip, i have effectively double the gripping force by adding this. at least thats the way it was explained to me. you definitely do notice a difference.
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
43030 (A51691)
43030 (A51691)
2006 APPA TL (A55787)
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
Hydraulic Hose Reel (A52377)
Hydraulic Hose...
2007 POLAR TANK CRUDE TRAILER (A55745)
2007 POLAR TANK...
