Laminarman said:Loosened her up again, reved her up, mowed a little and I think that's what it took. After scribing a line yet again and this time loosening all the bolts even more, I had "the moment". I tried to mow a small but high patch of field behind my house and all of a sudden she bogged down, BANG! and whirring, no blade turn, no broken shear bolt. All the plates moved and at that point I knew the slip clutch was slipping. An epiphany and I learned a lesson. She made some good smells as she burned off the oxidation for a few seconds, and then I tightened all things up. I appreciate all the help here.
I belong to boards or forums for astronomy, photography, Porsche's, Labrador Retrievers, hunting, fishing and wine. But this board takes the cake. I ALWAYS get answers fast, with courtesy and accuracy. I do appreciate this site so much and it is simply the most pleasurable to use, a GREAT community.
Well GOOD!
If you are up to the task of diddling around with the slip clutch you can quit buying bolts in bulk! You have shown a lot of folks that you do indeed need to keep on top of the slip clutch to keep it slipping. Now that it is free, it is easier to keep free and takes less abuse to loosen it up. But be warned, they rust up hard even in a shed!
Oh, the moderators here are very good at keeping us all on the straight and narrow, but the group is 99.9% mellow and helpful by nature anyway. Still, it's good to hear that the advice you got here was accurate, helpful and more importantly solved your problem. I'm sure the givers of advice appreciate it!
