iMatch vs. TS quick hitch vs. Northern Tools QH vs. Agrisupply QH....etc...HELP!!!
   / iMatch vs. TS quick hitch vs. Northern Tools QH vs. Agrisupply QH....etc...HELP!!! #21
I agree with you to a point but everytime you get off your tractor to make the change in height and connect the top link is time that could have been spent making the modification once and for all.
With no disrespect intended to anyone, are you saying one should "do it once and properly"?
I agree!
   / iMatch vs. TS quick hitch vs. Northern Tools QH vs. Agrisupply QH....etc...HELP!!! #22
Modifying the implement makes sense in an ideal world. However, some people probably don't have the welding or machining capability this might require. Also, modifying my wood splitter is way down on the priority list since I have to shut the tractor off and hook up the hydraulics to the power beyond anyway. Also, the splitter is on a stand and I wheel it up to the tractor instead of backing up to the implement. I may modify it one of these days so I don't have to spend the minute or two to adjust the hook, but a lot of other things will get done first.
   / iMatch vs. TS quick hitch vs. Northern Tools QH vs. Agrisupply QH....etc...HELP!!! #23
I agree!
Pretty much:)
I took one day or slightly less and modified all of my implements at once. Made sure all had the proper top bushings to fit as well as the proper lower adaptors. that was back in spring of 2009 and the only implement I have left to modify is the boxblade it was out on a jobsite the day I fitted the rest of the implements.
New Landhonor Gas Water Pump (A59000)
New Landhonor Gas...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
Dewalt D28493 7/9" Angle Grinder/Sander (A59076)
Dewalt D28493 7/9"...
2021 Kubota SVL75-2 Track Loader (A56436)
2021 Kubota...
2016 Club Car Carryall 1500 4x4 Utility Cart (A55758)
2016 Club Car...
