Implement Width
/ Implement Width #1
Geneha
Excelsior, AR
Kubota B7500
Hi I am new to this whole tractor world after moving from the big city. I just picked up a 2000 B7500 with a LA272 FEL, Rhino SE4 (48") rotary mower and a 48" box blade and love the this tractor. TBN was one of the website to join and get lots of info.
The B7500 is rated at 21HP / 16HT PTO (I think).
I have two questions.
1) Should the best width implements to stick with is 48" or are 60" too much for this tractor? I am looking at the King Kutter TG-48 3 PT tiller.
2) My second question is I am thinking the old blades on the Rhino are so worn out that it is causing some good vibration. I have just picked a new set of blades and hope this will fix the vibration issue.
Thanks in advance and looking forward to all the good advice from here
Gene & Jean
Greenwood, AR
/ Implement Width #2
Stick with the 48" for that size tractor and the new blades will probably solve the vibration although the old ones could have been sharpened and weight balanced and done the same (maybe). Welcome aboard!
/ Implement Width #3
The implement width will depend on the implement. A 48" would be good for a tiller, your BB, and even a rotary cutter.
But lighter load implements you would be fine with 60". Like a finish mower, scraper blade, landscape rake, etc.
I gotta ask though, how long does it take to cut an acre with only a 4" rotary cutter:D
/ Implement Width
I missed type that. I should read 48" or 4'.
BOAT MOTOR (A66738)
BOAT MOTOR (A66738)
2006 Hummer H3 4x4 SUV (A64557)
2006 Hummer H3 4x4...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 INTERNATIONAL...
2017 Ford Transit 150 Cargo Van (A66736)
2017 Ford Transit...
Unused 2024 Land Pride PF1242 42. Forks and Frame Skid Steer Attachment (A66734)
Unused 2024 Land...
2025 Hydraulic Tire Lifter Skid Steer Attachment (A66734)
2025 Hydraulic...
