Impliments for DK40se HST w/FEL
   / Impliments for DK40se HST w/FEL #21
Will check and get back to ya. They are middle of the road line. The box blade has been used for many hours - probably 200-300 hrs. Bush hog about 100. Landscape rake around fifty and the rear blade maybe 15. Post hole is in the 100's +.
Lloyd
   / Impliments for DK40se HST w/FEL #22
SITractor,
Models;
Box blade: BX 84
Post Auger: RPHD Regular Duty 9" & 14" bit.
Landscape Rake; LR 30
Bush Hog: 172 medium duty
Back Blade: 350
Lloyd,
Thanks for the info, I'll be checking those models out as well. I'd doing all my shopping on line until we move back to IL, then I'll have the opportunity to see things first hand. I want to narrow my choices down before we get there.
Thanks,
Mike
   / Impliments for DK40se HST w/FEL #24
The only thing I don't like is the colour. Although I haven't had it matched - which may be expensive - I do like to option of painting my gear once or twice a year to keep the rust off and stuff looking new(ish). I paint my bucket, pallet forks, and anything that is black with a coat of trem-clad just to keep things in check.
Lloyd
Lloyd, your impliments are the same one's my dealer is offering/recommending for me! If you are happy with these for the DK40, that is reassuring. I want to buy super-duty, but those kids and braces.....
Thanks,
Mike
   / Impliments for DK40se HST w/FEL #26
Hear you on the braces... one child needs them - starting next month. Other in a few years - maybe.
Been happy with everything. Broke one tooth on the box blade. Broke/cracked where there is an indent to lock into position. Bad cast. Unfortunately I did it after warranty was up. And it was the second time using it with the teeth down. All other stuff is holding up well. Auger drilled 350+ post holes and hit a few granite boulders on the way down. Sheer pins broke a few times - they did their job.
Good stuff...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A55852)
2012 Freightliner...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55302)
Neckover GL24-2-7K...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55302)
GMC 3500 Extended...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
