Impressions of my Dodge
   / Impressions of my Dodge #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I've owned my 2004 Dodge 3/4 ton 4x4 Quad Cab with the Cummins and auto transmission about 3 months now. It had about 105,000 miles on it when I got it and I've put about 2000 miles on it. I thought I would share my imprssions of it.
First off let me say there is really no sane reason for me to own a 3/4 ton diesel. Like a lot of 1/2 ton owners, there had been several times I had overloaded my half tons, so that is why I wanted a 3/4 ton, and I have always wanted a diesel since Dodge came out with them in the late 80's. So the truth is its more of a want than a need. My half ton Chevy with the 5.3 and 3.73 gears was getting a lot of 12mpg driving the same way.
First off the engine and drive train. Its what is known as a high pressure common rail. So far I think I'm going to be lucky in terms of the engine and injectors. Common rails can eat injectors and they can be costly to replace. The engine seems tight, doesn't use oil, it starts easy and pulls well. I've only towed with it once and that was about a 5000lb load, and it towed it well. I have 4.10's in it and the auto is a 4 speed. It needs one more gear, or 3.73 gears. Your really don't need 4.10's unless you tow heavy a lot. The truck has an early Edge chip on it and it was set to level 3 when I got it, I've backed it down to level 2. It also has straight exhaust, which I'm having changed out this weekend to more of a performance exhaust with a muffler. So far the transmission seems fine also. It rides rough empty, but it doesn't seem any more bouncy or skitish over bumps than the half tons I've owned. I have some rattles in the truck, sway bar end links if I were to guess. I can also tell the front drive shaft and some of the U joints have been replaced.
The interior. The interior of the truck looked much better than the outside of the truck when I got it. Its a cloth interior and looks and functions great. The only real problem is some dash lights are burned out, which are easy to fix, but so far I haven't really missed them. The CD player also refuses to eject CD's most of the time, but they do pop out after a few days of trying.
The exterior of the truck is where I was dissapointed after I got it home. I spent some money getting some rust repaired, but it looks great now. Its had a leveling kit put on the front, which I wouldn't pay for, but I will probably leave it on. It looks like the truck was used hard at times and it has a few scratches and dings, but I think it will hold up well for me.
Economy. So far about 14mpg on average. A lot of in town driving and rural driving. I've never really burned through a tank of highway driving, so I don't know what it will do on the interstate. I've used it some for my job, so that isn't helping the fuel mileage any.
I work with someone that owns a newer Duramax. The biggest difference I notice between his truck and mine is the noise. The Duramax seems very quiet compared to the Cummins. I'd also say his rides better.
   / Impressions of my Dodge #2
I hate those "tuners" / "chips" that people put on their trucks now. I hope you have good results from yours. If you read like any diesel forum you can see dozens of threads like "my new 6.4 blew up and ford wants $10k to fix it, help!" along with a signature from that poster telling about how he got 150 more HP because some guy on the Internet decided that was a safe thing to do, as if ford themselves didn't have a team of engineers figuring out a good balance of durability vs performance.
I think tuners are O.K. as long as you don't try to turn up your truck too much. Thats one problem with newer diesels, people can turn up a truck over 100hp with nothing more than a tuner. Mine is turned up about 40hp right now. There is no way around it, making more power isn't going to help long term durability.
As a side note, the newer (2011 and newer) Dodges with the Hemi have a rolling code in the computer that so far none of the aftermarket tuners have been able to crack. Its pretty easy to untune a car before you take it in and the dealer doesn't know the car had been turned up. My guess is this was done to keep people from hot rodding there cars and then asking for warranty work. I don't know if the Dodge diesels have this or not, but I don't think so.
   / Impressions of my Dodge #4
The Dodge trucks have the best diesel engine in the business. Period. The B series engine is amazing. It will reliably make 3 times it's factory output, gets great fuel economy and makes bottom end torque that the other makes can only dream of.
   / Impressions of my Dodge #5
The new 3 valve Cummings are weak in the mains and don't have the options of more machine work. The 2 valve bt6 is a far better engine than the new ones. I see quite a few smoked transmissions and rear ends from dodge. There trucks don't match cummins engines for durability. If you can put a ford rear end and a 6 speed manual in a dodge Cummings then you will have something.
Um, I think they are known as 24 valve engines, and you could get and can still get a 6 speed stick in a Dodge. I've never heard of the mains being a weak point. For my year, I think it could either be a 6 speed or a 5 speed stick, but mine has an auto. I've never heard of people having problems with the rear ends, but if they get turned up a lot, the auto transmissions and the clutchs on a stick can be weak.
   / Impressions of my Dodge #7
Thanks for the informative review Dave!
My father had the same truck, but regular cab. His routinely got 21 mpg on the highway, as long as he was driving conservatively.
A couple things we learned:
- A fuel pressure guage is a good way to keep an eye on the performance of the lift pump. In 04 they were mounted on the back of the fuel filter housing. Dodge changed this to an in-tank pump in 05, and was offering a retro fit kit. We opted to replace the existing pump with an original due to dealer issues, however it took us a while to diagnose and get parts. It left my 60 yr old father stranded twice on the highway due to the failing fuel pump.
- Apparently the dash panel guages and controls are prone to failure. Dealer replacements are very expensive ($1000), but I didn't research aftermarket or repairs. There are many repair options for GM gauge panels, so I assume there would be for the Dodge as well.
- The fan clutches are prone to fail, but you won't notice it in normal driving. The trucks cooling system is so strong that its not really stressed until you tow heavy in the summer or do some heavy snowplowing.
- Nothing cures the stop-squeak. Engine shuts down, all the the accesories screach to a halt. A new belt helps for a few cycles, but lasts a reasonable amount of time.
- The transmission in not nearly as fragile as most people say, but the wrong "techs" can destroy it quickly. My father's was perfect up to 70K miles. Heavy towing. Abusive plowing. Worked fine, fluid always stayed clear and clean. While at the dealer for the dash, he asked for a transmission service. Normal services were fluid and filter changes up to then. He witnessed then drain clear, pink fluid from the transmission. They replaced the filter and adjust some bands, and replaced the fluid. 100 miles later, the transmission would not shift to OD, and had late hard shifts. Back to the dealer. Fluid burnt. Dealer would not support him, and would not even SELL him a new trans. Which brings me to my final recommendation...
- Find a good Cummins mechanic or a trusted dealer with a diesel tech. Both dealers close to my father are terrible.
   / Impressions of my Dodge #8
No problems with the bottom ends in any Cummins b series.
Rear ends? They all have Dana 70's, 80's or the 11.5 AAM. ALL of which are stronger than the Sterling offered by Ford.
My gauges have "freaked" out a couple of times, but go back to normal. I have written on the radiator cowl that the lift pump has been replaced and the computer reflashed.
There is a diesel pick up repair shop that has a good rep. in my area. I will probably use them if needed. They are the ones putting on my exhaust this Saturday.
   / Impressions of my Dodge #10
The b series didn't come out until 89 and dodge used several series of blocks they used. The newer cumming 2006 and up have different valves than the b series. Known as a 3 valve. The engines last and the drive trains are ok but the trucks fall apart.
   / Impressions of my Dodge #11
Sorry, the 3 valve is Ford's modular engine term, the 5.4L and 6.8L gassers. Cummins has never made a 3 valve engine for light truck use. The 5.9L block was used from '89-'07. The 12v was from '89-'98, the 24v or VP was from '98.5-'02, the 24v CR (common rail) was made from '03-'07, and the 6.7L (also 24v) from '07.5 and up. All of the above are considered B series engines.
   / Impressions of my Dodge #12
Glad to hear you like your Cummins!
I have an '05 Cummins 2500 w/auto. It's been good so far for the year and a half that I've had it. So far, I've replaced the dome light ($40) and the three HVAC panel lights ($6.00 combined) which were all burned out when I bought the truck. Real easy to replace. Little typical Dodge issues like the wires going to the rear windows being severed and an HVAC blend door that won't work won't keep me from loving what big things the truck does well. I bought the truck for the engine, which, by the way, has never run out of power, and the ride is actually better than I was expecting from a 3/4 ton.
My typical mileage has been 17 hwy/13 city. Not bad for something rated to tow 13,000 lbs! Yours should do better in stock form, as the '04 is tuned more mildly than the '05. What yours will do with the tuner is anybody's guess.
You addressed "need" in regards to your decision to buy a diesel. I didn't really "need" a diesel either, as I could have gotten by with a 3/4 ton gasser. I got the diesel because I wanted it. I wanted it for the power, I wanted it for better towing economy, I wanted it for longer engine life and durability, and I wanted it for the sound!:cool:
I'm still glad I bought it!:thumbsup:
Joe
I've got to be honest that I may not know what I'm talking about, but I've never heard of a 3 valve cummins. The early ones had 2 valves per cylinder. Starting some where around 2000, they came out with a 4 valve per cylinder known as 24 valves. I assumed the new 6.7 litre Cummins was a 24 valve also but maybe not.
Edit, someone beat me to it, and confirmed what I thought.
Marveltone, I saw a show on speed channel, I thing Two Guys Garage, and they showed a kit for fixing the blend door on our trucks, it came with a template and you cut a big hole in your heater box, then fixed the blend door, and it came with a cover for the hole. It looked like a slick kit and easy to install, but they always make it look easy.
   / Impressions of my Dodge #15
I know of the kit. I've got their website on my bookmarks list, and it's a project I fully intend to pursue once it's warm enough to work outside again. Meanwhile, the door is stuck between floor and defrost, so at least it's in a useful mode. :cool:
Joe
   / Impressions of my Dodge #16
Considering what sounds like a real rough past for your truck, I'd say it's holding up pretty good. The only "common" problem I've had is replacing the front wheel bearing. I replaced both just for piece of mind but one was still in good shape.
My next truck will be a Cummins powered RAM but this ole 03 RAM HEMI has to die first and at 120k miles I don't see that happening any time soon. :thumbsup:
Got to love the know-it-all's that claim the Dodge trucks are junk with a good engine yet have no idea what they're talking about. Weak rear ends, 3 valve engines...? Pretty sure your thinking about Ford's their Jamming, not Dodge. :rolleyes:
   / Impressions of my Dodge #17
Mine is an '01, stock except BHAF and 4" exhaust. Got it new, just passed 150k miles.
I have been very happy with the truck. I came from Ford F250's with gas motors, mostly cause I got them used. My Dad was a Mopar parts guys for decades, when new time came, I went thru the shop he worked at. I coulda went elsewhere and got a Ford, but I liked the Cummins and the Dodge body style. I still like Fords, but have never gone for the hype of the perfect truck would be a Ford/Cummins/Alison...
I have been VERY happy with the truck(Ram-2500 long bed xcab Cummins/auto 4x4).
I would not get 4:10 gears again. That Cummins does not need that low gearing. 3:73 seems a better gear. Unless, you constantly tow a lot of weight.
I kind wish it had manual locking hubs. I grew up in Jeeps with them. Just a guess, but I bet it would get better mileage with tru hub disconnects compared to the contraption in the front axle.
I kinda wish I had went with a stick too. Auto has worked just fine, but I like shifting gears too.
   / Impressions of my Dodge #18
Love my 06 model, has 3:73 with the automatic... have a Smarty Jr set on Economy. (40hp)
Truck pulls anything i tie to the back of it....
OP, does the truck have an EGT probe installed and working? If not, I would probably install one since you have the programmer, especially when pulling. Programmers can easily put the EGT in an unsafe range when the engine is working hard.
BTW, Jamming, its spelled Cummins, not Cummings..
   / Impressions of my Dodge #19
Joe
Would you post a link to that in the event I ever have the blend door issue ?
Thanks
CASE 450CT SKID STEER (A60429)
CASE 450CT SKID...
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A61306)
2017 Ford F-550...
(2) BKT TR-387 TIRES (A60432)
(2) BKT TR-387...
2019 Ford F-350 4x4 Crew Cab Pickup Truck (A59230)
2019 Ford F-350...
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
2007 Ford F-250 4x4 Crew Cab 7ft. Flatbed Truck (A59230)
2007 Ford F-250...
