In the middle of 50hr service have question?
   / In the middle of 50hr service have question? #1
surfran
Platinum Member
Finger Lakes Region, NY
Kubota BX1800
I have pulled the strainer and the manual says to clean in a non-flammable solvent. What are non-flammable solvents? All the solvents that I know I have are flammable. Any ideas or suggestions would be highly appreciated especially since I do have a few filings I need to get off.
Of course I should have thought of this before starting. But this is going like a piece of cake so far I just don't want to use the wrong thing.
   / In the middle of 50hr service have question? #2
Brake parts cleaner; like BraKleen is non-flammable - and does not leave any residue.
nitronaut,
Thanks for that suggestion, just went to look and I don't have any of that anymore either. I am sure I did at one time, but haven't done a brake job in about 10 years. Any other suggestions?
Thanks again for replying.
   / In the middle of 50hr service have question? #4
If you have a compressor, you could probably just blow the metal off the screen, since it's on the outside. Mine did not have a lot. I hit it with the solvent...then blew it off. I'm not sure it really needed the solvent at this stage as there was no buildup of anything - just some metal on the screen.
Thanks again. Now I have uncovered another problem. It appears the dealer gave me the wrong oil filter. He suppliled me with a 70000-74034 part number filter. which appears much larger around. I just checked the parts manual I have from tractor smart and it calls for a 15853-32430!!! This just figures, everything was going too smoothly. No it looks like I will have to wait an take the filter back in the morning. And of course other half will be happy as we are leaving town for a family reunion in the morning.
Nothing ever goes as easy as it should.
   / In the middle of 50hr service have question? #6
I use mineral spirits and naptha to clean parts . after cleaning blow dry with a compressor.
And your right if it can go wrong it will! /forums/images/graemlins/grin.gif
   / In the middle of 50hr service have question? #7
That's the oil filter part number for the last one I bought for my B7500. The previous filter was part number 70000-15241. The dealer said the Kubota part numbers and filter colors change from time to time /forums/images/graemlins/confused.gif................chim
Chim,
Thanks, and that doesn't suprise me that they change either. This one looks to big, so I am headed over to the dealer this morning at 8:00 when they open to get the correct one. If they tell me this is it, I will be very suprised. I think it was just a mistake. I just hate to half finish stuff.
On the other hand the 50 hour service is a piece of cake, just like normal oil change on car except pulling the screen. It takes 26mm socket, so luckily someone asked the other day about that so I checked mine and found I didn't have a socket and purchased one. Also purchased the 30mm for the mower blades while I was at it.
If all had went well, even taking my time, this should have been 1 1/2 MAX. Of course posting on hear and coming in to check replies every few minutes adds time too.
Catch ya'll later.........
   / In the middle of 50hr service have question? #9
Surfran,
The 74034 number is the oil filter for the BX22/2200 engine. I don't know if it interchanges with the BX1800. It is the white "economy" version of the original black filter. It appeared and was larger than the original and first factory unit I replaced. But they said that was the current unit. I opted to go with the better fitting WIX filter instead.
Good luck,
Michael
   / In the middle of 50hr service have question? #10
Oh, to heck with the lawyers, I use gasoline, if it expoldes in my face it will be my fault. /forums/images/graemlins/shocked.gif. They are protecting you from a fire/explosion hazard. The wire screen will not be damaged by gasoline and the transmission will never know whether you used naptha or gasoline to clean that screen. J
2025 JMR 36in Mini Skid Steer Bucket (A53421)
2025 JMR 36in Mini...
Killbros 260 Seed Conveyor (A55302)
Killbros 260 Seed...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED AGT YSRT14 STAND-ON SKID STEER (A52706)
UNUSED AGT YSRT14...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
