Information/Help on a FORD SUPER DEXTA
   / Information/Help on a FORD SUPER DEXTA #1
Rebeldad1
Veteran Member
Hughett Bend Washington
Kioti Tractor, John Deere Mower,New Holland Mini Excavator
I have a chance to purchase a Ford Super Dextra. How good and reliable are they? This one is apart and not running. Are parts easily available?
Is assembly information on it available?
   / Information/Help on a FORD SUPER DEXTA #3
Yesterdays tractors web sight lists many parts for dexta's. Super dexta was introduced in 1964 with a few up grades including a slightly larger sleve for more horse power. The first ford perkins dexta started in england and exported from 1958-1964.When a older dexta is rebuilt it is with many super dexta parts.I own 2 dexta's and 1 super dexta.I highly recomend them as they are simple and dependabile.they are simular to the massey fergison with the 3cyl deisel. The 130 maybe? The most important task is to use the proper starting procedure.You must have a working pre heater on the intake and use a squirt of deisel to preheat. a heater in the lower rad hose works very well too. Many parts from the ford 600 work on dexta's,such as the dual stage clutch,spin out rims or reg rims. front wheels.the starter.it is a clumsey but fun tractor.3 speed trans low and high 6 all together.amazing pulling power. very easy on fuel. you may be able to get the one you are looking at for less than 1000.00.
   / Information/Help on a FORD SUPER DEXTA #4
Good little tractors..!
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
PALLET OF (20) BOXES OF ARMSTRONG TILE FLOORING (A60432)
PALLET OF (20)...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
