Inherent design flaw in the Kubota Grass Catcher
   / Inherent design flaw in the Kubota Grass Catcher
Spoke to the manufacturer of the gear box this morning and learned that the two halves of the case are epoxied together. That eliminates the possibility of swapping top for bottom of the case halves. Engineering suggested that the holes be drilled out and re-tapped to 3/8-16 thread if re tapping doesn't work out satisfactory. Also learned that the grease that they use is Amoco Perma Gear 220. I asked about checking the gear box for lube quantity and learned that the inspection plug is a self tapping type of plug that is put in with a sealant. Each time it is opened and reinserted, it will go farther into the case. They suggested that it not be removed unless there is a indication of leaking and that the factory fill of grease is good for many hundreds of hours of use before needing to be changed. For all practical purposes, it is filled for life. The Kubota manual suggests changing the gear lube every 100 hours, so you can decide what you think is best for you and your machine. Personally, I will take the factory suggestion and let it go ..... that is, if I ever cut that much grass before the rest of the machine wears out... /forums/images/graemlins/grin.gif
I re-tapped all the holes today and it seems that they might have originally been tapped with a worn out tap. It appears that once I get the longer bolts, everything will go back together with out any more problems.
The name of the company that built the grass catcher is Everride. They make ZTR Commercial lawn mowers. Here is a link to there web page.
   / Inherent design flaw in the Kubota Grass Catcher #12
Junkman,
You sure do have a way with getting information about stuff.........all kinds of stuff. I am going to file this away in case I ever have an issue with mine I will know who to call /forums/images/graemlins/wink.gif
Thanks again for sharing your hard work in digging up solutions and information.
The advantages of my background and being retired and having the patience to chase the information down. If you want to file away this information also, the snow blower, sweeper, front blade, and the quick hitch are all manufactured by Rad in Canada. I had the information about them also, but misplaced it on my desk. When and if I find it, I will post that also.
SKID STEER ATTACHMENT CEMENT MIXER (A58214)
SKID STEER...
2016 Ford Expedition (A56859)
2016 Ford...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A55787)
2017 Toro Z-Master...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
202473 (A54757)
202473 (A54757)
