thepumpguysc
Elite Member
Bummer.!!
I don’t think the engine times at TDC..??
I KNOW the pump doesn’t..
Do u have anything on the valve cover that tells u the timing.?
PMSMECHANIC IS spot on and I’m not telling you to do it any differently than what he wrote, I’m just trying different ideas to make it easier for ya..
Just FYI, the key will be pointing to the #1 cyl..
So if u get your ENGINE TIMED, and the nut and washer removed.. look at the key, say 10:00.. go around to the pump side and look at your #1 cyl to see if it’s close.(2:00)
It sure would be easier if they marked the balancer..
U said the flywheel was marked w a TDC MARK, didn’t you.?? To bad u couldn’t figure it out from there..
It would be nice if it was timed to TDC..
Good luck
Good luck
