I don't think the little copper piece actually holds them in place. I think it more like seals them. But, I've never worked on the exact particular injectors you're talking about. In general, they just have a little detent check ball to keep them aligned in the hole, and then the nut holds them down in place. On the ones I've worked on, some have had threads on the outside of the injector. I have an injector puller that is sort of like a slide hammer of sorts. You screw the one part on the injector and then use the slide hammer action to pop them out. Obviously, yours may be different. Some really suck when they are so stuck that the injector puller just rips the threads off of them. /forums/images/graemlins/mad.gif
