Injector removal
   / Injector removal #1
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
Anyone give me some instructions on removing injectors on YM1700?
Thanks
   / Injector removal #2
Once you remove the nuts and the flange, there is nothing but gravity and crud holding them in, usually more crud than gravity. You just have to get after them with penetrating oil and whatever else comes to mind, like oven cleaner.
   / Injector removal #3
i second what norm said its really pretty easy just make sure you clean the crud off
   / Injector removal #4
I have heard, but never tried: For really stubborn injectors leave the cap and nuts on slightly loose, and turn the engine over. The compression will blow the injector loose from it's seat.
Has anyone ever tried this? I have yet to try this as I have always been able to soak overnight and wrestle them free the next morning.
Mark
   / Injector removal #5
I have heard that also, Mark, except that Eddie has his engine apart.
   / Injector removal
It's on it's way back together now. Got pistons back in with new rings, waiting for machine shop to grind valves and install new valve seals.
It's getting a new water pump too, make it run a little cooler!!!!!!
   / Injector removal #7
Ask the machine shop to remove the injectors if you really need them out. They have ways and means. Probably a good idea anyway, then re-install with "antisieze".
   / Injector removal #8
Norm or others,
Do these injectors have an o-ring seal? I have a 1700 and the rear injector (closest to driver seat) is starting to leak. When the tractor is running; you can see little bubbles at the head and you can tell where it has over time run down the side of the motor.
The tractor runs fine, but little things like this annoy me.
Fig
   / Injector removal
I did ask the machine shop to get them out, I think they have a copper washer that seals them.
   / Injector removal #10
I don't think the little copper piece actually holds them in place. I think it more like seals them. But, I've never worked on the exact particular injectors you're talking about. In general, they just have a little detent check ball to keep them aligned in the hole, and then the nut holds them down in place. On the ones I've worked on, some have had threads on the outside of the injector. I have an injector puller that is sort of like a slide hammer of sorts. You screw the one part on the injector and then use the slide hammer action to pop them out. Obviously, yours may be different. Some really suck when they are so stuck that the injector puller just rips the threads off of them. /forums/images/graemlins/mad.gif
UNUSED FUTURE MINI EXCAVATOR COUPLER (A51244)
UNUSED FUTURE MINI...
1998 Dorsey Trailer, VIN # 1DTP16K29WG052604 (A48836)
1998 Dorsey...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A50854)
2011 ORTEQ ENERGY...
Skid Steer Gravel Leveler (A50515)
Skid Steer Gravel...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A50323)
2015 Freightliner...
