Installing a tooth Bar
   / Installing a tooth Bar #11
I thought about that but the way I was thinking (which doesn't make it right) was the material inside the bucket is already broken up and wont be as hard packed to mess the threads ups.
But I do like the idea of adding another nut on the end to help keep threads clean
Well I guess a lot has to do with where you live and how you use a bucket. My bil lives in Kentucky. We dig hundreds of feet of water line with hardly a rock. Here in New England, you cannot put a shovel in the ground w/o hitting a rock. If rocks were diamonds, I'd be a bezillionaire. At any rate, it is best to cover the threads to thwart any kind of build up or damage so as to work the bolts on and off more easily.
   / Installing a tooth Bar #12
I like to use these - Makes things looks more finished, keeps things (and you) from catching on the sharp bolt end, and protects the threads:
   / Installing a tooth Bar #13
Those inside and carriage bolts outside work great and you only need the wrench on the inside.
That would be nice but do they make them big enough? Great ideas!!!
   / Installing a tooth Bar #15
Use your angle grinder and cut the threads off flush with the nut.
Bruce
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
ROME AH-240 LOT IDENTIFIER 117 (A53084)
ROME AH-240 LOT...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
2022 Kobelco SK85CS-7 Excavator (A51573)
2022 Kobelco...
ECHO SRM-2120 GAS WEED EATER (A51248)
ECHO SRM-2120 GAS...
DEWALT 4400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 4400 PSI...
