Installing a tooth Bar
/ Installing a tooth Bar #1
2LateIWon
AGCO/CAT Challenger MT275
Here is a vid I did on installing the tooth bar in case anyone was interested
[ame=http://www.youtube.com/watch?v=6kJ45ZO1fdI]How to install a tooth bar (toothbar) and Review Harbor Freight drill bit set #00527 - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=6WnLnONIsyA]Tooth Bar installed and Turn an Ammo can into a tool box - YouTube[/ame]
/ Installing a tooth Bar #2
Looked good to me, just one thing, I find when drilling through metal and starting to break through, if you can go to the other side and drill, it won't catch because you have the pilot hole to guide your bit. John
Thanks and good tip jwnge Ill have to keep that in mind next time.
I just took my tooth bar off yesterday to get ready for the snow and ice we might get here in the next couple weeks
/ Installing a tooth Bar #5
Very nice video. When I installed mine, I set it in the bucket and clamped it in. I used the mounting brackets on the bar as a drill guide to go through the bucket. You might want to put on another nut on your mounting bolts to protect the threads so as to make removal and reinstallation easier w/o having to contend with damaged or mud caked threads.
/ Installing a tooth Bar #6
Why not put the bolt head inside the bucket? Would seem to reduce the probability of thread damage with the exposed bolt threads outside the bucket?
/ Installing a tooth Bar #7
Ralph beat me to it!
Also, put TWO nuts on, so the threads are protected, and it will be easier to take it off.
/ Installing a tooth Bar #8
It is better to have the head inside the bucket especially if working rock. Threads outside the bucket if not protected can get just as beat up. All it takes is scraping against one rock so they should also be double nutted no matter.
/ Installing a tooth Bar #9
Good point! And nuts are cheap, especially when compared to the work involved in using a hack saw or cold chisel.
I'm gonna' find a couple nuts to add to my toothbar bolts! :thumbsup:
I thought about that but the way I was thinking (which doesn't make it right) was the material inside the bucket is already broken up and wont be as hard packed to mess the threads ups.
But I do like the idea of adding another nut on the end to help keep threads clean
/ Installing a tooth Bar #11
Well I guess a lot has to do with where you live and how you use a bucket. My bil lives in Kentucky. We dig hundreds of feet of water line with hardly a rock. Here in New England, you cannot put a shovel in the ground w/o hitting a rock. If rocks were diamonds, I'd be a bezillionaire. At any rate, it is best to cover the threads to thwart any kind of build up or damage so as to work the bolts on and off more easily.
/ Installing a tooth Bar #12
I like to use these - Makes things looks more finished, keeps things (and you) from catching on the sharp bolt end, and protects the threads:
/ Installing a tooth Bar #13
Those inside and carriage bolts outside work great and you only need the wrench on the inside.
That would be nice but do they make them big enough? Great ideas!!!
/ Installing a tooth Bar #15
Use your angle grinder and cut the threads off flush with the nut.
Bruce
2024 CATERPILLAR D1 LGP CRAWLER DOZER (A65056)
2024 CATERPILLAR...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A67714)
TWO PALLETS OF HYD...
2019 Chevrolet Tahoe SUV (A66738)
2019 Chevrolet...
TOTE OF ROAD SIGNS AND TWIST LOCKS (A68842)
TOTE OF ROAD SIGNS...
PALLET OF TOOLS (A67714)
PALLET OF TOOLS...
2016 Ford F-750 (A64911)
2016 Ford F-750...
