Intake Manifol Heater
   / Intake Manifol Heater #1
hayboy48
West Central Alabama
Mahandria 4025
Just discovered my 2011 4025 with 250hrs heater is not auto timing out, left the switch on and noticed the intake hose smoking a little. Living in central AL, do I really need this if it cranking ok? Remedy just take hot wire loose, This is putting a drain on the battery even while running. Just working on a few bugs in this new to me tractor. Thanks
   / Intake Manifol Heater #2
Even though you're in a warm climate (like me), I still find it useful to use the intake heater whenever it gets below 40*. I just think it takes strain off the engine. I notice that the professional excavators use the glow plugs or heaters almost all the time. So they must know something.
One thing you could do is to splice in a manual switch to the hot wire, and run a lead to your dash where you could control the heater manually. Just my 2¢
   / Intake Manifol Heater #3
My 4025's intake heater relay quit working for some reason, so I went direct from battery to glow plug. I used anderson powerpole connectors, which allow me to make the connection, wait 20 seconds or so, start the tractor, and 20 seconds after that unplug. I will let the experts sort out the relay one day, but this works fine. BTW, I tried the 'wide open throttle to start' method, and it fires almost before touching the key!
-Simon
The splice in a switch I had already thought about. Keep it simple if it works, THANKS
1998 BOMAG BW172D-2 SMOOTH DRUM ROLLER (A52707)
1998 BOMAG...
2017 Ford Fusion Hybrid Sedan (A53424)
2017 Ford Fusion...
2009 Volvo VHD Tandem Dump Truck, VIN # 4V5KC9EF19N270338 (A51572)
2009 Volvo VHD...
2019 MACK P164T WINCH TRUCK (A53843)
2019 MACK P164T...
2025 Auger Skid Steer Attachment (A53421)
2025 Auger Skid...
Box of Transport Ratchet Straps (A55851)
Box of Transport...
