Interested in learning how to weld
   / Interested in learning how to weld #21
I am a self taught welder, and for me, a crappy welder. My stuff works, but would work better if I had time for a class. I started on a Lincoln Tombstone (Huge, Reliable, unkillable - but old technology). My wife got me a mig (lincoln 180C) but due to the fact I do not have a walled shop, and am too lazy to switch over to flux, It doesn't get much use. I bought an Everlast 200 for the price I sold my Tombstone and love it. Points above should help.
Power. OK, imo, you are doomed. as we all are. You will run a 50 AMP leg in (you know, this is something you can probably do yourself unless you have lots of money). Anyway, you will run one 50 amp leg, and in a year you are going to want a plasma cutter. And with that, the sudden realization that your little 110 compressor is not good enough and you need a 220 on its own circuit.
For me welding is addictive. Probably because as opposed to wood, it can look like crap and still be considered workable.
For your first welding project, you should build your welding table. Right of passage I was told by an older welder.
   / Interested in learning how to weld #22
   / Interested in learning how to weld #23
My first project was just that... I salvaged an old craftsman rollaway I pulled out of the dumpster at the recycle station. fixed up the drawers, put casters on the bottom. Then welded a piece of 2ft by 4ft by 1/2in thick plate table top onto the thin sheet metal of a tool cabinet. Talk about not pretty... and I won't show you the welds, but it works!
   / Interested in learning how to weld #24
The mig is easer to pick up but I would learn on stick 6010 and 7018 both dig deeper then mig.
   / Interested in learning how to weld #25
Depends on who's running the Mig! ;)
   / Interested in learning how to weld #27
Has it been that long already? WOW!:shocked:;)
   / Interested in learning how to weld #28
Don't forget the 'bell's and whistles'. Auto helmet, hand grinders, 3 at least, each with a different disc .One cut off and a hard grinding wheel and a flexible one. Can usually pick them up for $20.00. Not industrial grade but ok for home shop type work. Chop saw and band saw bench vice and as many vice grips as you can afford. Oxy / Propane torch and the list goes on.
Al
   / Interested in learning how to weld #29
For all around use, I still think an AC/DC stick rod machine cant be beat for the average farm shop. With the right assortment of rods, one can weld just about any thing with one of those and by adding a TIG torch and bottle, there is no limit to what can be done (assuming the welding experience is there). I have always said that an inexperienced MIG operator can put in more defective material in 5 minutes than a grinder can take out in half an hour.
A properly set MIG can be a joy to weld with, but when one is acting up, they are frustrating to say the least. There are lots of variables to contend with when troubleshooting a malfunctioning MIG and a novice will be pulling out all his hair trying to figure out what is wrong. A DC stick machine is much easier to correct any problem, just turn the dial up or down to correct 99% of problems with an ugly weld assuming that you have followed all the pre-weld requirements of cleaning, electrode selection, and fit-up.
   / Interested in learning how to weld #30
I almost forgot, a properly equipped farm shop must have an oxy-acetylene torch with some brazing tips also. A DC machine and the OA torch can fix just about anything used by a tractor on the farm.
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A54811)
2024 Wanco...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
1ST PRODUCT HYD MINI SEEDER / AERAVATOR (A52706)
1ST PRODUCT HYD...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
