MotorSeven
Elite Member
Roger this all depends on what kind of stove you are running. The newer stoves with catalytic converters must have wood with below 20% moisture or it just plain does not work very well. Older stoves like my '87 does not have a cat and can burn wood with a higher moisture content....however this is also not good. The reason is that you are expending heat to make steam, which means any stove is less efficient with high moisture content. Today's rule of thumb is cut spit and stacked for a year...two years is preferred. Kiln dried limber is around 6-7% & most air dried is around 10% if it has been covered and stacked with air movement around it(not tightly stacked). Your moisture meter sounds like it is way off....hardwood firewood cannot possibly dry enough in one month.
