Interstate Batteries
/ Interstate Batteries #21
Spiker mentioned a sulfate treatment...care to tell us a little more about it? Brand you like, active ingredients to look for, or some other identifying feature to identify a "good" one? Of course, sulfate treatments and/or replacing acid don't work very well on a sealed "maintenance forbidden" battery...
No specific brand, they used to sell it at HF and that is where I got the 2nd bottle from, the first was either NAPA or a local battery place cant remember now. Bottle was not cheap but sure seemed to help it last a long time. At one time that mail order cat, JC-whitney had it too but I have not gotten anything from them in a LONG time.'
Mark
Update: Got the new battery today well packed and looks good (black vs the original red). It slides right into the drill and charger no issues. Came fully charged and spun the drill very fast. True test will be drilling some one inch holes through a concrete wall and seeing how long it lasts of course. But for less than $80 I'm a happy camper so far.
/ Interstate Batteries #23
I have resigned to the belief that batteries are being designed with planned obsolescence. My old Chevy Delco battery (1978) lasted nine years. My first cell phone battery (1999) lasted eight years. My old boat batteries (2002) lasted 10 years.
Now new Diehard in my car (2012) lasted two years ($324). Napa battery (2010) in truck lasted 1 1/2 years. Interstate battery (2009) in my tractor three years.
I have decided to go with Walmart batteries and just keep replacing them on warranty every three years since they have one of the best warranties offered now and better prices.
We have a fleet of eight vehicles. We've only replaced one in less than 6-7 and that was on warranty. But the cars are driven a lot. Two are Red Top AGM's, one is a Odyssey/Diehard Platinum, and the rest are Interstate or Costco (both made by Johnson Controls).
/ Interstate Batteries #24
Use to sell Interstate at the Dealership... was a real good battery and priced right.
I no longer buy them since our good as gold jobber was forced out and he had a few choice things to say about declining quality.
Best Service ever was 12 years with a AC Delco "Green Eye" and Costco use to also sell these.
Best Battery Buy ever was from JC Penny... it had a lifetime warranty and got 22 years from that purchase up to the time the car was totaled...
We also had a battery additive called VX1 or something like that?
Very interested in your thoughts from field use with the tool battery line.
/ Interstate Batteries #25
Anyone heard of DEKA batteries? Possibly it's a regional thing. They seem to be quite common and as good as any other around here.
/ Interstate Batteries #26
DEKA is an excellent brand. They are made by East Penn Manufacturing and have both AGM and conventional flooded cell batteries.
Harley OEM batteries are Deka and worth the money IMHO.
Along with DEKA supposedly they make some NAPA batteries but those contracts can change. I bought a marine battery at West Marine a few years ago that was made by East Penn, and when I went back a year or two later they were made by JC.
/ Interstate Batteries #27
I've heard Dekas are great too. I called Napa 6 weeks ago to see what they had as far as marine cranking batteries and trolling batteries and was told only Napa brand. They told me they were made by Deka. I checked online reviews and Deka was reviewed favorably without fail, while Interstate was reviewed pretty poorly. The boat now has one new Napa cranking battery and two new Napa trolling batteries.
/ Interstate Batteries #28
BTW Interstate sells three different grades of standard battery plus an AGM.
Their AGM has a 48 month replacement while their entry grade is 30 months and Commercial 36. They are rated just as highly as anything else in CR.
/ Interstate Batteries #29
Has anybody every tried restoreing a old lead acid battery. I read, online no less, some russian dude had developed a method to restore old lead acid batteries that would no longer hold a charge. His method only worked for batteries that had not shorted out or had burn up plates. Anyway, his method was to completely drain the voltage from the battery and then hook a small battery charger up in reverse and charge the battery backwards. Supposely by reversing the electrical flow, the corrosion that had built up on the plates would flick off. After the reverse charging process, the battery was drained of the acid and flushed with water to remove the deposits, refilled with new acid and then charge properly. I have heard this actually works, but have never tried it myself.
/ Interstate Batteries #30
There use to be a small shop in town that rebuilt batteries... when they had the hard rubber case and the top was sealed with tar.
When I asked how it was done... it was basically taken apart, inspected for damage, given a good cleaning, the electrolyte strained/filtered and put back together.
Damage was often warped plates from heat, broken from vibration, or simply too far gone in thickness.
The old guy said most of the time... it was just a build up in the bottom of the case...
Entire shop was maybe 20 x 60... with vats, wood racks and rubber topped benches....
Did notice the owner did not have any teeth...
WATER TRAILER (A58214)
2008 JACK COUNTY 130 BBL VACUUM  TRAILER (A60736)
2008 JACK COUNTY...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2018 TROXELL 130BBL VAC TRAILER (A60736)
2018 TROXELL...
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
