Is a roller pump self priming??
   / Is a roller pump self priming?? #1
Pooh_Bear
Platinum Member
Dunlap TN 25 miles north of Chattanooga
Early 1949 Ford 8N
At 50 feet length and about 6 feet of height will a roller pump self prime?
I want to pump water from the river up to the garden this year.
I have pumped water before but I filled the pipes with water first.
I want to just drop the suction pipe in the water and start pumping.
I don't want to damage the pump by running it dry while it primes.
Hypro pump 11gpm@540rpm PTO.
Pooh Bear
   / Is a roller pump self priming?? #2
In general a roller pump will self prime. However, you should check the specs on the one you want to make sure.
   / Is a roller pump self priming?? #3
I would say the roller pump is not self priming, as it will need something besides air to pull water up 6'.
But worth checking the specs for sure.
   / Is a roller pump self priming?? #4
A vacuum will pull water about 30 feet. A self priming pump has to be tight enough to pull a partial vacuum which will draw the water. A roller pump should be able to seal almost perfectly under the roller.
   / Is a roller pump self priming?? #5
I don't have power available that far from the house.
Too far to even run extension cords (500 feet).
I just want to fill some barrels once or twice a week.
I'll water the garden out of the barrels.
The roller pump is the cheapest and easiest way.
I can prime the pump if I have to, but do I have to.
Will it hurt it to run it dry while it primes.
Pooh Bear
   / Is a roller pump self priming?? #7
It will not hurt the rollers to run it dry, and it should not hurt the hose, which has to be designed to be squashed flat by the moving roller.
I suspect the hose should be periodically replaced whether it runs dry or wet, but self priming should have little effect on its life.
6' of lift should be easily achieved by a roller pump.
   / Is a roller pump self priming?? #8
Here is a link to a HYPRO pump with 8 rollers. Note it is not a peristaltic pump running rollers around tubing.
http://www.hypropumps.com/en-us/Products/Pumps/Roller/7500/7560/
Thier claims are it is self priming.
I didn't find out how long they will run trying to "self prime". That might be a key.
Pooh Bear
Let us know how it works for you.
   / Is a roller pump self priming?? #9
I doubt it'll pick up at that distance. I got a 8 roller pump on top of a 100 gal tank on a spray rig and it only got to pull 3 ft. and it won't do that. I've replaced the rollers once and don't make a difference and I still have pressure prime it with the house water to get it to pump. You'll need to get a pump that you can actually stick in the water to be able to blo'n'go. bjr
   / Is a roller pump self priming?? #10
I do not know much about roller pumps but I am almost certain that my Delevan said do not run it dry.
   / Is a roller pump self priming?? #11
Would it be feasible to put a foot valve (check) on the inlet of your hose? Then you only have to worry about primimg it once. . .
I can't leave the pipe in the river. This has to be something I can set up and take down when I need it. Last time I pumped water out of the river I put a big tank filled with water on the suction side of the pump. The tank of water primed the pump and as it sucked water from the sealed tank more water was pulled out of the river to replace it. But I would like to simplify the process and not have to use the tank. A foot valve mite work but it would have to be primed every time I used it.
Pooh Bear
   / Is a roller pump self priming?? #13
self priming can be a hairy little thing. a centrifuge pump, diaphragm pump, piston pump, roller pump. they all can partially create a vacuum to pull water up into them. to self prime them. though i honestly would not recommend it.
if your tractor is 12v and not like my old allis chalmers 1954 i want say tractor with 6 volt setup. you can buy a 12v plug in cigarette lighter pump. and then buy some generic cigarette lighter for a car or truck on the cheap. put a 15 amp fuse between the cigarette unit and battery. and have a quick easy way to connect the pump up.
and the 12v pump might be enough power to fill the barrels up fairly fast and if not. a way to easily prime the roller pump.
WARNING / NOTE: your tractor may not be setup or rather have a large enough alternator on it. to handle a 12v pump for long periods. and you may need to let tractor set there and run for say 15 minutes or more to let the battery on tractor recharge back up. but if your tractor already has say front work lights, rear work lights, actual front head lights. tail lights etc... most likely no need to worry. but if you have bare bones tractor. you may need to let tractor run a few minutes after each use to make sure battery has juice in it. so when you go to start it back up. you do not have a dead battery.
-->strainer
-->foot valve, flapper check valve ((check valve that does not have a spring in it ))
-->hose
-->ball valve, knife valve, gate valve (any type of valve that you can easily open and close that is cheap)
-->hose
-->quick disconnect makes it easy to easily connect and un-connect hose from roller pump.
-->quick disconnect
-->roller pump
-->hose to barrels
doing above. you could trap water inside the hose that goes down into the water of the river. and might be a way to not need to prime things. though the hose would be rather heavy and very awkward.
as far as a 12V pump. i went out and bought a very cheap sump pump like 40 bucks. only a trickle of water at 10 feet of lifting water but..... i plug in a 12v to 110 converter (most eletronic stores have them) into cigarette lighter on my S10 blazer. and have primed siphon lines to drain lakes, pump water to buckets for mixing concrete before. and it is awesome granted i dare not turn off my S10 blazer for about 15 minutes afterwards or i will need to jump it. but hey, it works. that is all i care. what i tear up errr blazer on other hand. i haven't yet. well i almost did. electronics started to get a little dim there a couple times. and had to turn off the pump.
   / Is a roller pump self priming?? #14
So Pooh Bear, what is the plan?
Interested if you will follow boggen's plan of attack here.
   / Is a roller pump self priming?? #15
Back on post #5 of this thread I suggested a 12v pump, much easier way to go, I use these in my plumbing business and they are quiet, simple and efficient. Drop them in the water with a garden hose attached and start pumping. Since the pump is submerged priming in no issue.
Not sure whether the OP even looked at the link from his response.
   / Is a roller pump self priming?? #16
I looked at the 12 volt option. Too much money when I already have a roller pump. Last time I pumped water out of the river with my roller pump I used a 12 volt bilge pump plugged into my 4 wheeler to fill a tank that was inline on the suction side. When the tank and the suction pipe was full of water I connected it to the pump and that primed it. But it was time consuming to set up and get pumping.
I have a foot valve to go on the pipe. I can try that. Just fill the pipe with water and see if it will start pumping.
Pooh Bear
   / Is a roller pump self priming?? #18
Make sure you have a filter if you use the roller pump as it is not designed to use as a trash pump. Roller pumps are designed to move clean fluids at medium pressures up to about 300 psi which is necessary to produce a fine mist spray.
Not sure what you intend to save but good luck with it.
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
KAWASAKI 42ZV WHEEL LOADER (A60429)
KAWASAKI 42ZV...
2014 Freightliner 105' Bucket Truck (A56438)
2014 Freightliner...
Flatbed Truck (A55973)
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
