Is anyone using a Mulching Kit on a BX MMM?
   / Is anyone using a Mulching Kit on a BX MMM? #1
mshumack
Central FL, Florida
2015 Kubota BX2370 w/ FEL and MMM
I ordered a Mulching Kit for a 60" Fine-Cut deck. I should have asked here first - but is anyone using one, and if so, how do you like it?
Also, the Kubota Options sheet I have lists just one Mulching Kit for a BX2370/BX25, a "ZG3059" but the notes say this kit only fits the RCK54-P23BX mower and I have a RCK60-26BX 60" deck. I hope the Dealer did not order me a mulching kit for a 54" deck. I'll call on Monday to double check.
Maybe there is another part number for the 60" deck (just not listed on the Options sheet I have).
   / Is anyone using a Mulching Kit on a BX MMM? #2
I've had a kit on mine, a 60" regular deck since mine was almost new. A cant tell you if its the same for all the decks or not. I like mine. As I recall, the directions say to leave the deflector chute on but I removed mine. It narrows things up and distributes the grass a lot more evenly. The kit is pretty complete and has a lot of parts.
   / Is anyone using a Mulching Kit on a BX MMM? #3
I had one on my 54P. If it works as poorly as the one I had, save your money!
The kit costs $168, so if it doesn't work well I can always switch back to standard cut. At least it won't be an expensive lesson.
   / Is anyone using a Mulching Kit on a BX MMM? #5
Cheaper than here for sure.
IIRC, after the blades, the kit was 3 hundred something here.
   / Is anyone using a Mulching Kit on a BX MMM? #6
I remember it being several hundred dollars also.
   / Is anyone using a Mulching Kit on a BX MMM? #7
I have a mulching kit on my Dixie chopper. It sucks, and makes rows of unmulched grass. It works some better in leafs, but then the air flow comes out the front of the deck and blows dust up in your face. Pretty much it's only use is to reduce the chance of throwing rocks.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
2014 Lincoln MKX SUV (A59231)
2014 Lincoln MKX...
SCAN TO RECEIVE TEXT UPDATES (A60429)
SCAN TO RECEIVE...
CFG Industrail MX15RX (A53317)
CFG Industrail...
