Is the Cyber Truck a Flop?
   / Is the Cyber Truck a Flop? #741
That's one of several flaws with getting one. How long will the batteries last, what happens in winter when temps are below zero? Does the heat bother them over time? For now, it's an idea that I like, but doubt I'll commit to.
If we get an EV, it will probably be a small commuter car for my wife to run into town with. Currently she drives a minivan because we have 8 Akita's and sometimes, she hauls three of them at a time in their kennels to dog shows, or the vet, or to breed one of them. We'll always have to have a van for as long as we're showing dogs. But for a second vehicle, just to run to town, the EV is worth considering.
   / Is the Cyber Truck a Flop? #742
A lot of people here talk about buying a used truck. Who's going to want an electric vehicle that will need a battery replacement soon, that costs as much or more than the vehicle is worth?
I know that electricity storage is improving, will that apply to the old used vehicles?
An EV bought now will not have the same kind of resale value when older, as compared to an ICE vehicle.
   / Is the Cyber Truck a Flop? #743
That's what I just don't understand about EVs...
If a battery fails in a flashlight, do you throw away the flashlight?
If a battery fails in a vehicle with an ICE, do you throw away the vehicle?
Noooo...you take 5 minutes and swap out the old component and put in a fresh one, and they are standard sized and universal across manufacturers based primarily on voltage.
Battery powered vehicles should be the same way, you should be able to simply and easily swap out the battery.
EVs and their batteries should be designed to be interchangeable and standard sized (based on charge and performance), but which all manufacturers could easily cross-utilize.
Pull into a battery station (same as a gas station) pull into a battery swap lane, and based on 3 or 4 sizes (no different than 87, 89 or 91 octane or even diesel), deinsert the existing battery, insert a fresh charged battery (all mechanized and hands free), run inside for a pee break, grab a Gatorade and hit the road again...
Every battery would have a battery charge/health meter, and you could exchange a dead battery, but otherwise, it wouldn't matter if the battery was on the 100th charge or the 1000th charge. You use it, swap it on your next "refill" for another. Eventually a battery would be retired, but it gets recycled, but the cost is incrementally included in the cost of each battery "refill"...like a 5% tax.
The current approach is so anti-customer, and short sighted to install manufacturer proprietary batteries in every unique brand of EV.
It's like having Ford only gas, Chevy only gas, or Ram only gasoline!
   / Is the Cyber Truck a Flop? #744
EV batteries are more analogous to engines and transmissions than gasoline. All the EVs essentially take the same electricity which corresponds to gasoline.
I think the EV batteries have been quite reliable. I'm sure there have been some early failures, but there are early engine and transmission failures also. I think those replacements are similar in cost to batteries.
   / Is the Cyber Truck a Flop? #745
I've been wondering about the overall economy of EVs. It seems that the efficiency of EVs tends to be about 3 miles per kWh. The national average residential electricity cost is now about 18 cents/kWh. So the energy cost of driving an EV if you charge at home is 6 cents/mile.
We are about $3.00/gallon now which means to come out even, an ICE would have to get 50 mpg. If you had a car that got 30 mpg and drove 10,000 miles per year, you would save about $400 per year with an EV. Seems like it would take a long time to save enough to justify the EV.
It's worse if you consider the road tax that EVs don't pay (about $.50 per gallon for us) or if you charge at commercial charging stations.
Ev trucks might actually make more sense if you can deal with the range limitations because they would replace a lower gas mileage vehicle.
   / Is the Cyber Truck a Flop? #746
You have to factor in the vehicle cost also.
That's one reason we bought a new Kia Rio (we've had Hyundai Accents). Hard to beat 40 mpg, 10yr 100K mile warranty for under $20K.
   / Is the Cyber Truck a Flop? #747
Some have done well purchasing used for a few thousands with warranty remaining.
Co-worker bought Audi hybrid for 5k from auction.
It had a few months on warranty and the transmission went out… 13k to replace and later the battery light went on and Audi replaced the battery pack under warranty…
   / Is the Cyber Truck a Flop? #748
One last post and I'll leave it alone...
One might be able to have a friendly discussion that the EV battery holds the fuel - while the EV electronics and drive motors are more equivalent to the ICE engine and transmission.
But at any rate, with some easy basic design changes, it would be straightforward to decouple the battery to make it self contained and industry wide swappable.
EVs have very few shared standards today other than maybe the plug used to receive an external charging cord.
It seems the primary complaints with EVs which "everybody" makes (including EV owners, though maybe not admitted to) are:
1) limited distance per charge
2) Time required to recharge
3) high cost to surgically replace a dead/old battery
All easily addressed constraints with an industry standard swappable battery. It would remove the majority of the barriers to widespread EV adoption.
Well that, and maybe a redesign of the Tesla Pinewood Derby truck...
   / Is the Cyber Truck a Flop? #749
The problem with an industry standard swappable battery is that battery technology improving rapidly. A standard would be a line in the sand killing innovation. We may get there some day, but we wouldn't want to stop innovation this early in the game.
   / Is the Cyber Truck a Flop? #750
General guidance on EV batteries is to keep them between 20-80% for longevity. A swappable scenario would need to have a hard limit on those ranges or some way to report percent of use outside of the range. For fleet use, it may make sense. For personal use, I would not want a battery someone else abused.
We have a 2022 F150 3.5L and a 2023 Lightning (F150L). Paid more for the F150 than the F150L, both purchased new. F150L is our daily driver. Only charge at home.
I would not have considered a Cybertruck even if it was cheaper than an F150L. I have no concern with Teslas in general, but the truck doesn't seem practical and is fugly.
dsb
   / Is the Cyber Truck a Flop? #751
And why would you want to do that?
Are you really asking why anyone would like fast cars and pickups? A huge fraction of the market is dedicated to exactly this, a high-power sportier variant of any vehicle is usually the most desirable trim level, for a reason.
Do you like replacing tires prematurely?
No one likes replacing tires, but it's a small price to pay for fun. Also, wanting to have power available when desired or needed doesn't require you to go around spinning your tires all day everyday.
Has anyone suggested that? I do believe the cost of replacement is high enough that poeple might not want to invest that much in an older vehicle, esp. if they were already considering an upgrade. But I haven't seen any discussion of anyone "throwing away" their EV due to a need for a battery replacement.
This is already done to some degree, the Model S was famously designed with a large flat battery pack in the floor, to allow for quick battery swaps at a service center. Nearly zero customers were actually interested in signing up for battery swap plans, so they dropped it about ten years ago, but it's feasible.
But doing this also requires compromises in everything from handling to interior space, as the vehicles are typically designed around the massive weight of these batteries. In the case of the model S, I think it resulted in an undesirable step-in height, that some customers complained about.
Most of the data available so far shows these batteries are still above 90% capacity at a quarter of a million km. If we assume the typical customer might plug their car in overnight every 200 km, that's over 1000 typical charge cycles.
I don't think most EV owners are charging their battery to 100% and then waiting for the thing to hit 0%, before bothering to charge again. Most probably plug the car in when they get home, anytime the thing drops below 50%, depending on the length of their daily commute.
I'm not sure I follow this? Most customers will never need a battery replacement. So, you're saying "zero charge" is anti-consumer? Let's not pretend the average person will ever have to swap batteries on their EV, failure is rare.
Recent studies have shown that only 2% of new EV buyers will ever need to buy a new battery, a substantial fraction of which are those damaged in accidents and covered by insurance. In fact, although the data is too "young" to be conclusive, but all indications are that EV's built after 2016 (newer battery tech) should cause the replacement rate to drop below 1%.
   / Is the Cyber Truck a Flop? #753
All the damn leaf peeping tourists a month ago...
I guess we are damn leaf peeping tourists in your opinion even though we live in the woods and in the country, my wife still likes to go for a drive to see the colors.
In fact, the last 2 weekends we have been trail riding in the side by side a couple hours north of home for 2 reasons, 1 the colors of the leaves and 2, the trails close on November 1st for hunting season.
   / Is the Cyber Truck a Flop? #754
Not necessarily. The charge regulation circuitry could be built into the battery packs to allow for innovations in battery technology. Standardized input/output voltages, with all the custom circuitry internal.
Biggest issue would be shape/size of the packs. The way the batteries are built into the framework of the vehicle varies a lot.
Not an unsolveable problem, but it would require standardization.
Don't know what circles you run in, but "huge fraction" is a bit of an exaggeration. Yes there's a market for sports cars, but it's certainly not all-inclusive. As far as trucks go, maybe you're one of those who doesn't use his for actual hauling, and/or don't live where snow and slippery roads are a concern. When I buy a truck I look at towing/hauling ability, not 0-60 time.
I dunno, I think most of us outgrew peeling out by the time we were in our early-mid 20s.
   / Is the Cyber Truck a Flop? #755
Tesla attempted with government funding to develop a quick swap battery system but as far as I know the prototype worked but was not economically feasible..
   / Is the Cyber Truck a Flop? #756
Lots of EV in the neighborhood and many are Tesla.
This week a Tesla Truck joined the neighborhood EV fleet.
   / Is the Cyber Truck a Flop? #757
That’s simply your opinion, and is certainly, not a proven fact.
Battery swapping has been tried, (not in the US). It’s not such a great concept.
Being able to charge at home is a big draw for EV adoption, not ease of charge at a station you have to drive to.
Imagine your brand new, one week old EV truck at it’s first swapping station, getting your healthy brand new battery swapped out for some old used one.
In addition, some of these vehicles employ the battery structure as an integral part of the chassis assembly.
   / Is the Cyber Truck a Flop? #758
I love seeing the leaves change, it has always been a big part of why I stayed in New England. What disrupts people, not only me, is when you are trying to go somewhere and tourists are holding up traffic, driving well below speed limit, say 35 in a 50. (most speed limits in our rural area) Stopping on the side of the road for pictures in areas where they can't fully pull off road, and causes a two lane to become 1 1/2. Nearby Franconia Notch in NH has gotten better, it is a major highway that naturally goes down to 1 lane each way, with people parking everywhere despite that, and walking across the road like they are in the right.
   / Is the Cyber Truck a Flop? #759
Just curious, in Cali do people want an EV, or are they being forced to buy with ICE possibly being put out to pasture? Admittingly, I do not keep up with Cali politics. Not trying to be a wise ass, genuinely want to know...
It is entirely possible that EV is the culture forming there.
   / Is the Cyber Truck a Flop? #760
Sure, this will vary with where you live, sports cars are expensive luxuries. But there isn’t a house in my neighborhood without at least one hi-performance car in the garage, and several have more than one.
Remember that the founding principle of Tesla was, “EV’s do not need to be boring, they can be high performance“. They were specifically targeting the higher end portion of the market, with all of their early development effort. I suspect part of their reasoning in chasing this market was an acceptance that the new technology will remain expensive in the early years, so targeting the desires of enthusiast type customers makes sense than chasing the bottom of the barrel value market customers.
My truck is used almost exclusively for bad weather and towing, I have other cars to drive when it’s nice out and I’m not hauling. But I’m not sure why you would even bring this up, as these attributes are not exclusive, in fact they’re directly linked to one another in most cases. The gasoline or EV engine package with highest towing capacity will nearly always be the one with the best 0-60 times.
MASSAGE CHAIR (A58214)
Sakai SW354 (A60462)
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
