Re: Is the shuttle on GST equipped kubotas \'power\'....
Kind of a little of both. The Kubota manual will tell you "raise up and shift the shuttle shift lever forward to obtain forward speeds and shift it backward to obtain reverse speeds without using the clutch pedal".
then it goes on to say:
important:
"reduce engine speed to low idle before shifting the shuttle lever".
So i don't think it's the power reverser you see in some farm tractors where a solenoid allows you to shift from forward to reverse while moving forward at great speed, but it doesn't need clutching, either.
