Is the shuttle on GST equipped kubotas 'power'....
   / Is the shuttle on GST equipped kubotas 'power'.... #1
timo
se michigan
Is the shuttle on GST equipped kubotas \'power\'....
...or do you have to clutch to change direction?
thanks?
   / Is the shuttle on GST equipped kubotas 'power'.... #3
Re: Is the shuttle on GST equipped kubotas \'power\'....
Kind of a little of both. The Kubota manual will tell you "raise up and shift the shuttle shift lever forward to obtain forward speeds and shift it backward to obtain reverse speeds without using the clutch pedal".
then it goes on to say:
important:
"reduce engine speed to low idle before shifting the shuttle lever".
So i don't think it's the power reverser you see in some farm tractors where a solenoid allows you to shift from forward to reverse while moving forward at great speed, but it doesn't need clutching, either.
   / Is the shuttle on GST equipped kubotas 'power'.... #4
You also do not need to clutch to change from to another.
MarkV
   / Is the shuttle on GST equipped kubotas 'power'.... #5
you don't need to use the clutch, but if your have any speed it feels like a car wreck because it will slam you into the steering wheel when you reverse without thinking. then you will need to step on the clutch while you hold the mashed parts of your neither region
i found that out the hard way
   / Is the shuttle on GST equipped kubotas 'power'.... #6
My bad, I meant to tell Timo that you don’t need to clutch to change from one gear to another. And I do agree that you better back off on the throttle when you go forward to reverse at speed.
MarkV
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A54756)
KNOW BEFORE YOU...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A55788)
2006 International...
UNUSED LANDHONOR LHR-BLC9021 TOOL STOOL (A54757)
UNUSED LANDHONOR...
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2019 DODGE RAM 2500 HD SERVICE TRUCK (A51406)
2019 DODGE RAM...
