Is there any way to allow the MMM raise and lower without 3 py. doing the same?
   / Is there any way to allow the MMM raise and lower without 3 py. doing the same? #1
montelatici
Platinum Member
Croom, Maryland
Kubota B2601 and L3560 HSTC LE
Putting the MMM in "Top" blocks it from lowering and raising and a 3 pt implement can be used without the MMM raising and lowering. Is there any way to block the 3 pt. from lowering so that a small ground engaging implement can remain on the tractor while mowing?
   / Is there any way to allow the MMM raise and lower without 3 py. doing the same? #2
Chain it up.
ron
It will not hurt anything?
That's what the "Top" setting does for the MMM hydraulics. I guess, so good idea. Thanks.
   / Is there any way to allow the MMM raise and lower without 3 py. doing the same? #5
Shouldn't, if you take the lift links off. Raise it up, install chain (s), let it down on to the chains, remove lift links, go mow.
ron
Ah, I see.
   / Is there any way to allow the MMM raise and lower without 3 py. doing the same? #7
On my BX2200 I can remove the lower lift arms from the lift lever and pin them to stationary points on the frame, so that the lift lever moves but the arms(which are no longer attached) remain stationary.:)
   / Is there any way to allow the MMM raise and lower without 3 py. doing the same? #8
Which tractor are you talking about, some have the mower lift mechanism attached to the TPH lift arms. The BX2200 and possibly the BX1850 has tabs on the rear frame to attach the TPH down links that hold the arms stationary, see pic.
   / Is there any way to allow the MMM raise and lower without 3 py. doing the same? #9
ah, so that's what those are for!
they also make nice chaining points when trailering....
guess i should have read the manual better!
amp
Found a solution. Two turnbuckles one end hooked and the other end loop and two "D-Links". Attached "D-Links" to closed end of turnbuckle and hooked the hooks to the chain stop turnbuckles. Bungee cord holds the disconnected upper lift to lower arm connectors. while disconnected.
CAT 336FL EXCAVTOR (A55745)
CAT 336FL EXCAVTOR...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A55314)
2019 Krause...
