IS THIS TRACTOR WORTH $4500.00 ?
   / IS THIS TRACTOR WORTH $4500.00 ? #21
Duke I think you may be fine. A tractor that age can have some dings on the skin for sure. Often times they have seen very little use for the past 20 years.
Putting on a new seat and cleaning up / paining the rear wheels/FEL frame will greatly enhance it looks. Typically if they start and run fine and the clutch is strong enough to kill the engine at low speed in a high gear they are OK tractors.
I doubt you plan to use it 80 hours a week plus the bushhog will give you traction when using the FEL with heavy loads. You can pick up some nice chain on forks for like $150 if interested.
A new FEL alone would cost about what you paid for the rig. We wound up with our 1983 JD 310 BH after looking for a FEL for the late FIL nice 265 MF because we got a solid 60 HP JD tractor (3020 era I have been told) with a full size BH with a 7.5' FEL for about the same price.
Your $4500 deal would have been more like $6-7K if it was mint and may have not have had any more life in it. I enjoy the old BH because I can use it without concerns of making a boo boo on the paint or sheet metal more so than with the FIL 1976 265 MF with 1300 actual hours even though it is not mint but is for its age. It still has all of it OEM lights and they work. :)
If you have a few wrenches you will be able to keep it up I expect.
   / IS THIS TRACTOR WORTH $4500.00 ? #23
Do you know if it has inpependant PTO? If not you will want an overrun clutch if you plan on doing any mowing.
   / IS THIS TRACTOR WORTH $4500.00 ? #24
That unit with bush hog and FEL will bring what he is asking here in North Carolina...
I've seen people ask the moon for those x000 units because they are very popular...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2012 TRAVIS 39FT DUMP TRAILER (A54607)
2012 TRAVIS 39FT...
Tennant 800 Ride-On Street Sweeper (A53421)
Tennant 800...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
