IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #11
Yea Junk, we know you and love you for it. Although I'm still a bit peeved about the flowers I sent after your medi-vac incident. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif Well, to be truthful, I didn't send them but I thought seriously about it. Boy, would I have felt dumd as the real story unfolded.
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #12
</font><font color="blue" class="small">( wonder how long before we might be using one oil/fluid for everything )</font>
Funny enough.. I know some old tractors that spec 50w engine oil in the trans and diffy/steering box.. vs a hypoid gear oil.. and with their age.. can also use that same 50w oil inthe crankcase to get some oil pressure /forums/images/graemlins/grin.gif
Soundguy
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #13
Soundguy,
I don't think that 50W would crank over very good up here in the winter /forums/images/graemlins/smile.gif
Ben
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #14
I used hydrailic fluid purchased at Sam's (Walmart) and it is compatable with Kubota UDT!
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #15
Do you use Kubota UDT in the Kioti???? How do you know that Sam's/Walmart hydraulic fluid is compatible with the Kubota UDT? Is it stated on the package????
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #16
</font><font color="blue" class="small">( How do you know that Sam's/Walmart hydraulic fluid is compatible with the Kubota UDT? Is it stated on the package???? )</font>
I think it was when I bought some last year. I may still have a pail in the garage, I'll check.
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #17
I checked the pail, the statement is "recommended applications" and it then lists Kubota UDT among others.
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #18
<font color="blue"> Boy, would I have felt <font color="red"> dumd </font> as the real story unfolded. </font>
That would be dumB, dummy. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/tongue.gif /forums/images/graemlins/wink.gif
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #19
are you able to mix udt and super udt together. if not does Chevrons All-Weather meet udt or super udt specs. right know i use super udt and was wondering if i have to drain my fluid to switch over to chevrons stuff. /forums/images/graemlins/confused.gif
   / IS WALMART HYDRAULIC FLUID USE OKAY IN KUBOTAS #20
Yes, it states it right on the container!
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2014 INTERNATIONAL 4300 18' REEFER BOX TRUCK (A54607)
2014 INTERNATIONAL...
More info coming soon! (A53421)
More info coming...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2016 PETERBILT 579 DAYCAB (A53843)
2016 PETERBILT 579...
