Iseki 2140 hydraulic problem 3pt lionkage
   / Iseki 2140 hydraulic problem 3pt lionkage #11
If the pump is not leaking and you have relief pressure, then I would not mess with the pump.
Moisture will condense on cool metal, and over time, you will see milky fluid if you do not run the tractor hot enough to heat the fluid up.
Even though you changed out the fluid, you are still mixing up some of the old fluid and it will look milky and or fomey.
Thanks JJ. I'm getting sort of options! How about the valve linked with the up/down lever? Is this accessible?
Success! The problem was finally traced to the second Pressure Release Valve situated underneath the block which carries the upper arms of the linkage. The PRV was removed without altering the spring tension adjustment nut. and opened to reveal the spring and the orifice which had sufficient dirt to interfere with the valve. After reassembly the 3pt linkage worked - at first half heartedly then after an overnight rest- perfectly. I hope this helps others with the same problem. Finally thanks to all of you who have given helpful advice.
   / Iseki 2140 hydraulic problem 3pt lionkage #14
Hi 636rjb is your hydraulics still working ok? As I have the same problem on ours.
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
Magnetek RDS 500 Diesel Generator (A55272)
Magnetek RDS 500...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A55315)
2017 KINZE...
New/Unused AGT Industrial YSRT14 Mini Skid Steer (A57453)
New/Unused AGT...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
Power Line Pressure Tank (A57454)
Power Line...
