J Deere 4300 front axle oil leak
   / J Deere 4300 front axle oil leak
I went to the local dealer yesterday, and from what I can tell, the earlier tractors had tapered roller bearings where a large nut was used to preload them and hold the assembly together. This also required a hydraulic press to take them apart. According to the stamp on the dipstick pad, mine has ball bearings and the assembly is held together with a snap ring. The repair manual only mentions a press for the tapered roller type, and not for the ball bearing type.:eek:
   / J Deere 4300 front axle oil leak #12
I had the same problem with my JD 4400, 2000.
I took it apart and replaced the seal and it still leaked. There is a steel plug like a freeze plug in the motor. It is under the casting where you found the 4 bolts.
I had a branch push it out and lost the oil. Replaced it and no more problems. It took 3 tries and some gasket seal to get it in the right place. I used the same glue to re mate the housing between the 4 bolts and the gear shaft housing.
Stubut
1998 Wabash National 48ft T/A Flatbed Trailer (A56858)
1998 Wabash...
16ft. T/A Utility Trailer (A56859)
16ft. T/A Utility...
GMC 2500HD 4wd Service Truck (A56436)
GMC 2500HD 4wd...
Informational Lot - Shipping (A56436)
Informational Lot...
TANK MANIFOLD (A58214)
New/Unused 2 Post Car Lift (A57453)
New/Unused 2 Post...
