Jacking up a vehicle for an oil change
   / Jacking up a vehicle for an oil change #41
Wooden blocks are fine as jack stands. The Portsmouth "Kittery" Naval Shipyard uses wood block cribbing to hold their subs up in the drydock to work on, so wood IS reliable. However, they do need to be large enough, positioned properly (not so the weight is going down the grain like you were going to split it), and be the proper kind of wood. Small, soft, pine blocks don't cut it very well; whereas a heavy, dense elm is nearly indestructible.
   / Jacking up a vehicle for an oil change #42
"Solid wood blocks".....??? All wood can split. I have never used wood for that purpose nor cement blocks....and I don't know if anyone has ever used my method for when a jack stand will not work: I have a number of older 14 inch rims and tires, stacking two of those atop each other will work great as an emergency support. I recently had to put new rear brakes on my GMC and there wasn't enough room on the axle for both a floor jack and jack stand, so I used a pair of those rims and tires under the frame toward the front of the vehicle. I never got underneath it but wanted the backup support just in case the floor jack might fail as I was working on the truck.
YES solid wood blocks.
   / Jacking up a vehicle for an oil change #44
Whenever I have 4x4 or 6x6 left over from a project, I cut them into short sections to use as blocks. I don't worry about them splitting anymore than I worry about my deck falling down. If you do stack them however, be sure to "pyramid" them so they don't tip if you are going very high.
Years ago, I built my own ramps with 1/2 inch plywood with strategically placed 4x4s inside. They were quite heavy but they worked well. As I noted earlier, I don't use ramps now because I rotate tires every time I change oil and need to jack on the frame anyway.
Story about the BMW accident said his body must have tripped the jackstand lever....every jackstand I have seen and used cannot possibly be released and/or lowered if it has weight on it. There must be a type I am unfamiliar with. Very sad that it happened to such a fine young man.
   / Jacking up a vehicle for an oil change #46
I use wood blocks on occasion. I have several large ones leftover from when the timberframers put up my post and beam. Wood is what they use when jacking a house. You do have to be sensible though as 2x4 can easily split.
   / Jacking up a vehicle for an oil change #47
If you have 750# (1/4 of a 3000# car that has 50/50 weight distribution) on a jackstand that has 1" from the tip of the "tooth" to the pivot and 5" from the pivot to the end of the handle (an effective lever length of 4"), you only need 188# of force (per my math) to lift that corner of the car.
I could possibly see that if you were reefing on a breaker bar and pushed against the lever with your foot you might push hard enough to do that?
I don't know, sad for the family though.
Aaron Z
   / Jacking up a vehicle for an oil change #48
I've used wood under tires quite a bit but not so much under the chassis.
   / Jacking up a vehicle for an oil change #49
If you have 750# (1/4 of a 3000# car that has 50/50 weight distribution) on a jackstand that has 1" from the tip of the "tooth" to the pivot and 5" from the pivot to the end of the handle (an effective lever length of 4"), you only need 188# of force (per my math) to lift that corner of the car. I could possibly see that if you were reefing on a breaker bar and pushed against the lever with your foot you might push hard enough to do that? I don't know, sad for the family though. Aaron Z
This is the very reason I won't own the type that use "Gear Teeth". All my jack stands utilize a U bolt to adjust the height. That leaves two points to hold the load.
Chris
   / Jacking up a vehicle for an oil change #50
Chris
I'm not familiar with that type...could you post a link to an online image, perhaps?
Thanks.
My Hoe
Miller Delta Weld 452 (A57454)
Miller Delta Weld...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Steel Dump Hoist (A57454)
Steel Dump Hoist...
2013 Nissan Rogue SUV (A56859)
2013 Nissan Rogue...
New/Unused 8in Bucket (A57454)
New/Unused 8in...
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
