JD 1025R vs GC1710 eval being cut short
   / JD 1025R vs GC1710 eval being cut short #21
Thanks IrvingJ... printing that reply out and putting it in my tractor folder. Very useful to me! I found a shipper through uship and was quite pleased with his service.
Even though I haven't used the backhoe for more than an hour, I have an idea for a fabrication project that will make puttiing it on/off very easy... at least the alignment stuff.
At this point, I think the Sears will continue to do mowing duty and the MF will get jobs that involve moving/lifting/throwing stuff. I'm not quite sure what a quick-hitch assembly is but I'll keep looking.
Hey... it's not just 400 hours that's similar. I think I'm in there, or ahead of you, on that aging body thing!
First pic on this page has a good view of the front quick hitch:
Massey Ferguson GC2400 Photo Gallery - TractorByNet.com
   / JD 1025R vs GC1710 eval being cut short #22
I have a 1026r. Around 100 hours. I take the mower on and off every time i mow so far it works great. Just do it on concrete. The loader has been on and of at least 10 times no problem. I really liked the gc2400 and i thought it was the best scut for the money. Problem was the dealer was 80 miles away. Five deere dealers closer.
   / JD 1025R vs GC1710 eval being cut short #23
The auto connects that don't work correctly are not a product issue. It is 100% a dealer set up issue. If they aren't aligned properly, then they will not attach/detach properly. Once aligned properly, they work as advertised.
Now the procedure to align them properly might be too complex, and that is a product flaw. But it is one that is easily overcome with set up mechanic training.
   / JD 1025R vs GC1710 eval being cut short #24
I concur with popsie & adj187.
I have a new JD1026R (2012 model) with 50 hours. The dealer aligned the drive-over quick connect deck perfectly. I have no problem, except the mower deck sliding on my sealed, smooth concrete pole barn floor - easily cured with a rubber mat or concrete.
Even my wife was ok with me upgrading from my JD 445 tractor due to this feature, as I am getting too old to roll around on the concrete floor hooking up mower deck pins & drive shafts, etc. IMHO, it is definitely a beneficial feature for "those of us of a certain age" and / or various body damage :rolleyes:.
I think you will like it.
   / JD 1025R vs GC1710 eval being cut short #25
Try hooking up a 9' sickle cantankerous sickle bar if you want frustration. Seems to complicate the situation that I always do it in the 100 deg. heat.
Bingo!
I once owned a NH 451.
Great mower but a PIA to attach.
SDT
White 255 Disc (A50774)
White 255 Disc...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
12" Tooth Bucket (A50774)
12" Tooth Bucket...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
2018 KENWORTH T680 SLEEPER TRUCK (A52141)
2018 KENWORTH T680...
