JD 1640, 2040, 2240 Rockshaft Assembly
   / JD 1640, 2040, 2240 Rockshaft Assembly #11
Some parts personnel don't want to trouble themselves with looking up the part # & part availability.
   / JD 1640, 2040, 2240 Rockshaft Assembly #12
Thanks Jim. I figured out how to align to cam follower with the lever. After lowering the lever to the L position it dropped it down so it was easily visible from the rear to facilitate aligning it with the cam follower. Thanks also for the recommendation to replace the Ring seal. I had not noticed that it was missing. Likely the root cause of the leak in the first place.
   / JD 1640, 2040, 2240 Rockshaft Assembly #13
Thanks for update. I'm glad you got it repaired & you're welcome.
Jim
   / JD 1640, 2040, 2240 Rockshaft Assembly #14
You have the cam started correctly in the lever but the bulge(knot) on the cam needs to be above the lever(parts key 4) so lever can be adjusted up/down for L,LD & D or max to min depending on tractor model.
im working on an older 1020 with the same deal as this, you are saying the point of the cam goes into the slot behind the little roller on the tuning fork ?
   / JD 1640, 2040, 2240 Rockshaft Assembly #15
Welcome to TBN
I was told a long time back that a photo is worth a 1000 words. Look below at photo
   / JD 1640, 2040, 2240 Rockshaft Assembly #16
Thank you, TX Jim! That picture is exactly what I needed today! Happy Father’s Day to all.
Jim
   / JD 1640, 2040, 2240 Rockshaft Assembly #17
You're welcome. Happy Fathers day to you & every other father.
   / JD 1640, 2040, 2240 Rockshaft Assembly #18
Hello, I have the JD 2040, if the selector lever is in any position except D, the arms rise to full height, regardless of the depth control setting. I suspect the the sping on the cam follower is broken, as I do not see it looking through the trans filler port.
   / JD 1640, 2040, 2240 Rockshaft Assembly #19
Welcome to TBN
If control lever is moved to rear of quadrant 3 pt should raise fully in ""all L/D settings"". Are you indicating 3 pt arms raise when control lever is forward in quadrant? I can't remember if spring is visible through hyd filler hole. Do you have access to a bore scope?
   / JD 1640, 2040, 2240 Rockshaft Assembly #20
Thank you for responding. The 3pt arms raise and lower with the control arm, only when "D" is selected, any other setting, the 3pt arms raise fully with the control arm fully down/forward. I don't have access to a bore scope but will be getting a smaller inspection mirror that I can insert through the trans filler port.
2008 International Bucket Truck (A55973)
2008 International...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A55973)
2017 Chevrolet...
2014 Chevy Malibu (A56859)
2014 Chevy Malibu...
Mini Skid-Steer Hydraulic Side Shifting Forks (New/Unused) (A59225)
Mini Skid-Steer...
2024 Ex Mark Lazer Z 60in. Zero Turn Commercial Mower (A55973)
2024 Ex Mark Lazer...
