JD 2240 Hydraulic Geyser
   / JD 2240 Hydraulic Geyser #32
37 year ago my sr mechanic told us to modify that shiftcover to give return oil a bigger path back to the reservoir .
Just for your information. None of the manuals refer to the hole. Has nothing to do with gaskets or O-rings. Finally found a mechanic locally that is familiar with the problem. That is a manufacture hole that had a bearing plug that evidently blew out. Doesn't go anywhere. Doesn't provide fluid to anything. It's dead end. John Deere can't help, no info. Nobody knows why it's there.
Tapped the hole with 10-24NC tap & placed a 1" machine bolt covered in Locktite. Works like a charm. NOW YOU KNOW the rest of the story.
Thanks for all your help.
John Deere Z930M (A57149)
John Deere Z930M...
2004 INTERNATIONAL 7400 20FT TANDEM AXLE FLAT BED (A59575)
2004 INTERNATIONAL...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
Yale Warehouse Forklift (A57149)
Yale Warehouse...
Heavy Duty Solid Steel Skid Steer Mounting Plate (New/Unused) (A59225)
Heavy Duty Solid...
2014 SHOP MADE MANIFOLD TRAILER (A58216)
2014 SHOP MADE...
