JD 2305 PTO Shaft Adjust Procedure-rear case failure
   / JD 2305 PTO Shaft Adjust Procedure-rear case failure
your friends are beautiful.. border collies
thank you for the reply.
do you have a john deere oem parts supply, who has john deere 'upgrades'; original equipment manufactured [oem] you may recommend ? in need of, replacing the worn out units [1500 hours];
1. cross bearing #am37184.@$39.80 x 2 units
2. yoke #m15054.@$36.64.
3. opposite yoke #m150575.@$41.89.
re: mfwd driveline parts; universals and yokes.
Found aftermarket suppler who has improved 'heavy duty' or
jd oem 'upgrades' should be their 'heavy duty' trade name;
as jd listed ' wheel bearings' upgrades. replacement for bushing/sleeve on jd riding mowers, etc. any suggestions are welcome. reading many jd owners, these owners are asking for improving thier oem parts with heavy duty or jd upgrades, than to replace, known 'weak' and 'aluminum' oem parts. thank you again and happy tractoring
BUBBAX-
You should move your post to here:
Parts/Repairs
It's more about what your trying to get at where this thread is not.
   / JD 2305 PTO Shaft Adjust Procedure-rear case failure #12
My 2305 J.D just chewed up 10 bolts I figure from the crown gear in the differential. While pushing leafs. Heard a loud noise like cable under high tension. Was in 4wd low at time. Drove it back to garage approximately 50ft.front wheel drive only. Serviced tranny found metal shavings in tranny oil. Serviced Suction filter and found it full of metal shavings and then...10each 3/8" x 1" L bolts approximate size. 2 ok,4bent and maybe 4 snapped off. To me this seems like poor construction? I am hoping J.D. Will do something for me as it was a $25,000 purchase with backhoe,loader,mower 54". 7years of service does not seem like I got a fair deal on this tractor of a lifetime purchase... help. Is this fixable?
   / JD 2305 PTO Shaft Adjust Procedure-rear case failure #13
Uh oh.. Read about that scenario, repeated many times a,lung owners of pre-09 2305s. So far, no one has seen an adequate JD response to their engineering failure... Search here for those threads, lots of good warning for us '05 owners... I'm a little nervous about hitching up my rototiller...
PALLET OF MIRRORS & GLASS (A58374)
PALLET OF MIRRORS...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A58018)
2019 INTERNATIONAL...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2006 GMC C5500 BUCKET /SIGN TRUCK (A58018)
2006 GMC C5500...
