JD 2320 Wont Go Up a Hill After Warming UP
   / JD 2320 Wont Go Up a Hill After Warming UP #1
thurman2320
Athol, NY
John Deere 2320
Re: John Deere 2320 Hydrostatic Tractor w/loader and backhoe.
After being run for 15-20 minutes, the tractor will no longer go up a moderate slope in 2 wheel drive in either Lo or Hi range. (It goes up okay the first couple of times before it warms up.) It goes up okay in 4 wheel drive. Everything else seems to operate normally and it goes okay on flatter ground. Hydraulic fluid is at the proper level. Cannot see any obvious problems. Tractor is about 4 yrs old with 265 hours on it. Anyone have any ideas?
   / JD 2320 Wont Go Up a Hill After Warming UP #2
Has the trans fluid & filter been changed & the filter screen cleaned?
That is where I would start.
   / JD 2320 Wont Go Up a Hill After Warming UP #3
Why won't it go up, what does it do? Loses traction, stalls, slips out of gear, shuts off, bucks, etc etc?
Fluid and filters were changed at 150 hours (approx. 2 years ago).
Symptoms: It starts to go up the slope then acts like the transmission/clutch is slipping. It wants to go, but something isn't connecting.
   / JD 2320 Wont Go Up a Hill After Warming UP #5
Always have to start with fluids I would think. Goes up fine in 4wd?
Guess I will have to check the filter and screen as a starting point.
It does go up the slope in 4wd; I assume the front wheels are pulling it or its taking enough load off the rear wheels so that it goes up okay.
   / JD 2320 Wont Go Up a Hill After Warming UP #7
Has to be the transmission fluid and screen but the part about works in 4wd is interesting. Keep us posted on the resolution.
   / JD 2320 Wont Go Up a Hill After Warming UP #8
If not fluids and filters, sounds like the transmission will need some attention. Good Luck. Ken Sweet
   / JD 2320 Wont Go Up a Hill After Warming UP #9
After being run for 15-20 minutes, the tractor will no longer go up a moderate slope in 2 wheel drive in either Lo or Hi range. (It goes up okay the first couple of times before it warms up.) It goes up okay in 4 wheel drive. Everything else seems to operate normally and it goes okay on flatter ground. Hydraulic fluid is at the proper level. Cannot see any obvious problems.Tractor is about 4 yrs old with 265 hours on it. Anyone have any ideas?
In the tractors 4 years,do you know if at any time was the suction screen removed and cleaned?
Greg
Greg: Suction screen has NOT been cleaned (I thought it had been when I changed the filter and fluid). I must be getting more senile than I thought. Will do that at the first opportunity and hopefully that will resolve the problem.
Thanks to everyone for their replies.
Takeuchi TB153 Excavator (A45788)
Takeuchi TB153...
NEW WOKIN 4 GAL OIL PUMP NEW SUPPORT EQUIPMENT (A40023)
NEW WOKIN 4 GAL...
2008 Toyota Tundra SR5 Crew Cab Pickup Truck (A42744)
2008 Toyota Tundra...
2018 Nissan Rogue SUV (A42744)
2018 Nissan Rogue...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
2018 Ford F-150 XL (A39160)
2018 Ford F-150 XL...
