JD 2640 looses power
/ JD 2640 looses power #1
spayne67
LRAFB, AR
John Deere 2640
I was disking our arena with our 1980 JD 2640A when I noticed it was loosing power. I barely made it out of the arena when it died on me. It will start up fine and run for about 20 seconds and die. My first thought is fuel filter but if that does not work, but filter is clear and no air bubbles; what else could it be?
/ JD 2640 looses power #2
Change the filter and if that fails blow the supply line out from the tank. You have a fuel restriction somewhere.
/ JD 2640 looses power #3
If changing filter and checking fuel flow from tank doesn't fix it then probably the check ball in fuel return line fitting at inj pump is plugged. easy way to check is loosen the 2 screws on inj pump timing window. Be sure rubber gasket is loose,crank engine and if it runs for an extended period of time clean out check ball. Also get prepared($$$$) to have inj pump worked on as drive ring in inj is deteriorating plugging check ball.
STIHL FS80R POLE SAW (A64276)
STIHL FS80R POLE...
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
2025 Kearney 7'x14' Trailer (A64119)
2025 Kearney...
Roll of Barbed Wire (A64119)
Roll of Barbed...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
1997 Chevrolet Kodiak C6500 Aerial Crane (A62613)
1997 Chevrolet...
