JD 3020 cat 2 to cat 1 attachment?
   / JD 3020 cat 2 to cat 1 attachment? #1
MNBobcat
Platinum Member
Hi All,
I may pick up a used Wallenstein BX-42 chipper tomorrow. The Wallenstein site doesn't say if its cat 1 or cat 2 but I'm pretty sure its cat 1. My 3020 diesel takes cat 2.
I have a farmer friend who said you could buy the stuff to adapt a cat 2 tractor to run a cat 1 implement. Before I buy this chipper, can someone confirm I can get an adapter? If so, what all do I need (pto and pins?) and do you happen to have a rough idea of cost?
Thanks!
   / JD 3020 cat 2 to cat 1 attachment? #2
   / JD 3020 cat 2 to cat 1 attachment? #3
I had the same problem when I bought my current tractor. Picked up a few sets of the adaptors mentioned above and they work great and are cheap. You could also buy cat 2 pins for the chipper, if the ones on it are removable, if you never plan on using it with a cat 1 tractor.
Sounds like its much simpler than I anticipated. I thought perhaps there was a difference in the PTO shaft/coupler as well.
If its only a set of bushings it doesn't get much simpler than that!
Thanks!
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
Adams Load Out Conveyor - Stainless Steel Assembly - Baldor Electric Motor (A56436)
Adams Load Out...
2020 Deere 50G (A53317)
2020 Deere 50G...
