JD 350 400 or 450
   / JD 350 400 or 450 #11
rvaitor,
Can you give us a ball park number on what the dozer cost?
And how you found it?
Later,
Dan
   / JD 350 400 or 450
Thanks for the comments - I've been off line for a while. I did a little research on this machine and it was 're-lifed' about 4 years ago. The repair order paid by the taxpayers of Tennessee was $48K. Best I can tell almost everything was replaced.
I like the substantial roll over protection and cage although that doesn't insure you won't get hurt. My neighbor says those cages are great when you hit a hornets nest. The bees can get in and you can't get out.
Here's a picture.
   / JD 350 400 or 450 #14
I would be a little ticked if I was one of those taxpayers. It is a fine example of a JD350 but nothing worth 48000$.
   / JD 350 400 or 450 #15
You also must have a RV you fly around in?
John
   / JD 350 400 or 450 #18
I have not started on a RV yet. I have been real close a few times. I just got my RVator the other day in the mail. I am hooked on the RV-7. I have a spot for a easy 4000' strip on the side of a bean field.
Good luck with 350c. Just work the brush with the corner of the blade angled and tilted to dig around. Then push from the middle with the blade high. On big stuff you can work from both sides around to make a ramp. That way you can push higher. Has anyone on this fourm gussed was your ID Name was before?
John
   / JD 350 400 or 450
You should be able to take off and land 6 or more times in 4000 ft - if I can buy a parcel north of our property I could probably get 3400 ft. right now it looks like about 2100 ft.
I've got a good friend with a RV-7 and several others with other RVs flying or in process. Mine has been dormant for several years.
Thanks for the tips - I'm concerned it won't be big enough, but I also didn't want to buy something worn out and have some huge repair bills. I feel very good about the condition of this unit. My objective is to clear out some growth around the structures on the property, clear some fence rows and clean up an old orchard.
   / JD 350 400 or 450 #20
My goal is to have a nice light twin one day so I will need a longer strip. Also have friends with spam can that might be using it. Boy it is fun to dream of stuff to do. I hape to get my D4C back togather in the next few days. I have a new rake for it. I have the blade and C frame off it now changing pins, bearings and lines. I hope to have it up for the long weekend. We are still dry. So I can finnish up on some projects.
John
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
