JD 3520 ehydro jumping out of gear
   / JD 3520 ehydro jumping out of gear #11
That could be what happened. I was in a frantic mode trying to get the seed out and packed before it rained.
Got rained out the week before and I didn't want to wait another week.
Everything was a blur at the time but I do remember now that the lever was hard to reach because I had the 3pt spreader lower to the ground than normal.
I could have shifted my weight enough turning around to open or close the lever on the spreader that I triggered the safety switch.
Thanks for the info.
I second, that it could have been lifting your weight off the seat. I have done that many times.... Turning and trying to look down at the PTO or something and lifting my weight just a little to much. The tractor stops in it's tracks.
Finished my food plot yesterday taking my time without rushing. Sure enough when I reached back too far to move the shut off lever on the spinner spreader I came off the seat and the tractor stopped.
Tried it again and really watched what I was doing. Reached back came off the seat some and it stopped in its tracks again. I didn't realize that I was doing it the first time. It really didn't take much weight shift on the seat to stop the tractor.
What I thought was a mechanical problem turned out to be a physical one, me.
I was running the spreader lower than normal which made it harder to reach the lever because I didn't want a very wide swath as my food plot is not very wide.
Still would like to extend the length of the lever on the spreader.
Thanks to all who offered advice.
   / JD 3520 ehydro jumping out of gear #13
I'm sure this won't be the popular answer but I bypassed the seat safety switch with a wire splice. I mainly did it so I can stand up and look over the hood when slowly moving into something with the forks. I really don't see the point of this on a ehydro since when your foot comes off the pedal the tractor stops as well. It could be an issue if using the cruise control but I don't really don't ever use my cruise.
   / JD 3520 ehydro jumping out of gear #14
You most likely hit the forward and reverse pedal at the same time even for a split second the machine did what it was supposed to do I think your machine is ok!
If you were in hurry this is easy enough to do I have done it myself and wondered what the heck was going on thought my new tractor was broke untill I looked up the error code >)
   / JD 3520 ehydro jumping out of gear #15
Hi Greg I have 140 hours on my machine now and unfourtunately many of them are rough cutting some pretty nasty lots, I always take my time and try and keep the machine clean. However recently I have been noticing that when I go to shift my shifter lever is stuck, I really have to give it a good little push to get it to shift then everything seems fine again. I have been worried that something got broken inside my machine (oh god what a nightmare to split it apart and have a look) but after reading your post I am wondering if it is just a linkage adjustment. When the machine is off it shifts perfectly and smooth 90 percent of the time it seems fine then all of the sudden it will be hard to shift again then fine again. It never did this before. I am under warranty but my dealer I prefer is 2 hours away not sure if I should be bothering him about this yet!
   / JD 3520 ehydro jumping out of gear #16
Since the 3720 is an eHydro machine, I'm not understanding your use of the word "shift". Are you referring to the range select lever? If so, for what reason(s) do you seemingly "shift" it so frequently? Mine spends 99% of the time in mid-range (B), using high-range (C) only when up on the highway enroute to doing occasional tractor work for friends and neighbors. And I bet I haven't used low-range (A) more than twice since I've owned it.
//greg//
   / JD 3520 ehydro jumping out of gear #17
Yes sorry Greg range selector. I use it when I have to leave the road and drive over curbs into rough terrain for rough cutting development lots. Going from C for highway use to B and 4 wheel engaged, then returning to road and trying to disengage 4 wheel and return range selector to c position when I find sometimes it is stuck and have to really give it a good jolt to move it.
Sometime mine is hard to shift so I just press the forward or back pedal a little bit and it comes out. Same thing for getting it in gear.
Just some, not all the time.
If the tractor is kinda stuck in its place it can be hard to shift. I know when I park mine in the shed before I lower the bucket to the ground I can shift it to neutral smoothly.
If bucket is on the ground where the tractor won't move an inch it seems to take a little more effort to shift to neutral.
Acts like the tractor needs to be free to move just a touch to free up the shifter.
Again, not all the time.
   / JD 3520 ehydro jumping out of gear #19
Ditto for my 2005 3520.
- Spindifferent
   / JD 3520 ehydro jumping out of gear #20
Yup, there are no clutches involved in selecting an operating range. And you can't shift on the fly either, this must be done at a dead stop. Range select is strictly a matter of aligning gear cogs. Most of the time simply moving the tractor back and forth an inch or two does the trick.
//greg//
2025 K2030 UNUSED Metal Garage (A50860)
2025 K2030 UNUSED...
Handicap Lift For Bus (A50860)
Handicap Lift For...
Adams FL24 Fertilizer Conveyor - 24IN Belt, Predator Engine, 2IN Hitch, Refurbished by Manufacturer (A51039)
Adams FL24...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
2011 MACK GU713 (INOPERABLE) (A50854)
2011 MACK GU713...
2025 K4525G UNUSED Double Garage Steel Barn (A50860)
2025 K4525G UNUSED...
