JD 3720 Noisy Hydraulics
   / JD 3720 Noisy Hydraulics #1
TC33DA
North Carolina
I needed to move some dirt and gravel the other day and noticed my hydraulics were noiser than normal. The outside temperature was in the 40's so it was cold. I let her warm up for 10 minutes and the engine temp was normal. When I raised the FEL the hydrualics were noisy almost a winning noise. Same from the the 3 pt when I raised the box blade. No issues when moving the tractor. It is a hydro. I know the hydra fluid is thick when cold but thought it should have warmed up. Maybe not since I did not really work it.
   / JD 3720 Noisy Hydraulics #2
Did it quiet down after using the FEL for a few minutes? If yes it was probably the cooler oil. Since the tranny is HST the charge pump helps warm it but this heat is not transfered to the FEL circuit until you start operating it.
Roy
FEL was still noisy after running the system. Talked to dealer and he said the "screen" before the pump might be dirty. Only has 100 hours so it is in warranty. Headed to shop after holidays.
2024 Chevrolet Tahoe SUV (A56859)
2024 Chevrolet...
2022 Ford F-150 XL Pickup Truck, VIN: 1FTFX1E88NFB46449, Super Cab, 4 x 4, 3.5 L EcoBoost Gas (A59076)
2022 Ford F-150 XL...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2012 John Deere 650K LGP Crawler Dozer w/ 6 Way Blade (A59213)
2012 John Deere...
2008 CAT D4K XL (A58216)
2008 CAT D4K XL...
72" General Purpose Skid Steer Bucket, S/N 103581 (A59076)
72" General...
