JD 4115 Hydrostatic Hydraulics slow to none
   / JD 4115 Hydrostatic Hydraulics slow to none #1
wauke
John Deere 4115 hydraulics very slow to raise bucket and rockshaft not working at all. new hydraulic pump, new rockshaft control valve, new filter, sump screen clean, pressure line screen clean. pressure set at 2300 psi, pto works, tractor drives forward and reverse. no leaks
HELP!!
   / JD 4115 Hydrostatic Hydraulics slow to none #2
Have you checked/measured the pressure that this new system is producing?
Need a pressure gauge.
:welcome: to TBN
Currently 2300 psi measured at the tilt ram. I do not know where the fluid is going. A new pressure relief valve is on order.
   / JD 4115 Hydrostatic Hydraulics slow to none #4
did the pressure relief valve solve the problem?
FENCE PANELS (A58214)
Topsoil Trommel (A57453)
Topsoil Trommel...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2012 International Prostar (A56438)
2012 International...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
