JD 4120...rear remotes pressure
   / JD 4120...rear remotes pressure #1
whitedogone
Central Illinois
JD 4120
I am having issues with my new grapple install. I'm not sure if it's my plumbing or a problem with the rear remote pressures. The grapple opens fine as far as speed. But it closes very slow and with hardly any force. I was thinking of making a pressure gauge up so I could just hook it into the rear remotes to check the pressure of both those first. What pressures should I be looking for?
   / JD 4120...rear remotes pressure #2
The valve probably came set to a specific pressure. It is up to you what the pressure should be.
Whatever someone set on the remote relief pressure , or it might read the PRV on the FEL valve. I believe using multiple valves, you set the reliefs the same. You could set the remote relief lower than the FEL, and that way, you would know which relief was showing the pressure.
Check those QD's for correct hookup, re-reconnect if necessary
   / JD 4120...rear remotes pressure #3
The fact it closes slowly with very little force might mean you are moving the lever too far and going into "float and the grapple is just drifting down from gravity. Try pulling back a little on the lever and see if that solves your problem.
   / JD 4120...rear remotes pressure #4
You can expect to see the relief pressure from either valve. Normally all reliefs would be set the same.
Bench Grinder (A57454)
2008 JLG 800S MANLIFT (A58216)
2008 JLG 800S...
6ft Teakwood Indian (A57454)
6ft Teakwood...
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
2018 Kaufman 20-Ton Equipment Trailer, VIN # 5VGAP2528JL004708 (A57453)
2018 Kaufman...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
