JD 4300 Lift Link BREAKING!
   / JD 4300 Lift Link BREAKING! #21
The hydraulics should stall before you get close to breaking that unless you are somehow rolling the implement and it's putting a whole lot of extra strain on the system to try to keep it level. My 4300 was missing one side when I got it so I just welded one up with parts from agrisupply and made a new draft link for about $100 total and have never had an issue. I have a ~2000lb counterweight I carry back there and it's always jumping up and down while doing loader work. I've stalled the 3pt out before picking up the front of a truck with a carryall and had no issues with anything breaking.
Right lower link is bent to the outside
Where is the lower link bent? I don't see it.
When it broke. All I did was hook up the disc, put the sway pins in and pull up on the 3pt lever. AND SNAP!
   / JD 4300 Lift Link BREAKING! #23
Are you sure the rods are on the correct sides and not switched putting them in a bind when lifting. Or even half the rod is turned around wrong, maybe the bottom half that goes over the arms.
After looking at the manual and my 3pt setup. The bottom toke of the lift links were reversed. They had the grease cert on the inside, they need to be on the outside? Hope that fixes the issue.
   / JD 4300 Lift Link BREAKING! #25
Glad to hear you have it figured out!
2007 FONTAINE TRAILER CO. 48X102 SPREAD AXLE STEPDECK (A52472)
2007 FONTAINE...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
New/Unused 7ft 20 Drawer Stainless Steel Workbench (A51573)
New/Unused 7ft 20...
